I think I found the limit of stock LT1 head gaskets:)
Jordan I'm not sure if Sleeper has a P-trim or not, but the T76 from turbonetics that is used in the turbotech kit is a p-trim wheel. I would like to try a GT80 with the new R-trim wheel or GT-Q wheel and see how that setup would flow.
Jose
Jose
My GT 76 had a q-trim wheel. Jordan do you have any room to swap housings if you have to? The tangenal housing flows a little better then the on center which I had. I would have needed a 1.15 housing for my 383. It would have hit the fire wall with the turbo tech kit.
I thought externally the .96 and 1.30 on-center housings were the same? It shouldn't effect the spacing with the turbotech kit. I may end up trying the 1.30 housing if the .96 spools well enough.
Jose
Jose
I have a tangental, ill see ho the .96 works.
The next step is a GT80 R-trim.
but, I have nitrous also, so I am not TOO concerned with the 76 not making the power I want
Brandon Wittmer
Dec 3, 2014 09:28 PM
