How to remove pulley from an S-Trim?
Old Jul 28, 2004 | 11:20 PM
davepl's Avatar
I'd like to change the pulley on my S-Trim while its still in the car. Last time I tried just for curiosity, and after taking the bolt out it clearly wasn't just sliding off, so I let it go. But now I have belt slip and would like to try my Reichard Ultra-Grip pulley to see if its worth any improvement.
From the people I've asked I've heard everything from "heat it with a propane torch for 10 minutes" to "pry it off with two screwdrivers". Both scare me...
What's the hot ticket to removing and replacing a pulley on these units?
Many thanks! Before you ask me how the Ultra-Grip pulley works, please help me install it
Old Jul 29, 2004 | 12:50 AM
97WS6SCharged's Avatar
Re: How to remove pulley from an S-Trim?
Last time I changed a pulley, I just removed the blower from the car. It should be 6 bolts, an oil feed and return line, and the intake tubes. Anyway, a standard gear puller was all I used.
Javi Fierros
Jun 1, 2015 11:41 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
