How much vacuum?
Old Mar 29, 2012 | 08:30 PM
Jasonz28camaro's Avatar
How much vacuum?
How much vacuum should my car be pulling? See sig below.
before I put the procharger on the it was pulling about 10-12 max on idle. Now with the procharger installed it pulls 15 max. Is this a good thing or bad thing for a FI car?
Old Mar 29, 2012 | 11:20 PM
mrmint69's Avatar
Re: How much vacuum?
I get around 18-20 usually. I was between 15 and 18 when the car was stock. My Camaro manual says that around 20 means a healthy engine with no mods.
Old Mar 30, 2012 | 09:57 AM
Let's move this to the Forced Induction forum.
Old Mar 30, 2012 | 07:49 PM
thanks for the input
Old Mar 30, 2012 | 08:34 PM
96capricemgr's Avatar
Cam is going to play a huge part in idle vacuum.
Old Apr 16, 2012 | 07:11 PM
mzgp5x's Avatar
Mine pulls about 3 psi @ idle. 13 psi best @ some cruz speeds. Had to go with a seperate vac pump for brake booster. Hope this helps.B.97ss 383 - D1 procharge mm6 trans,
Old Jul 7, 2012 | 01:42 PM
OBE1 95Z28's Avatar
Your idle rpm will also affect how much vacuum you pull.
Old Jul 10, 2012 | 01:45 PM
The SRZ's Avatar
9-10" on a good day. Cam and idle plays a part in it all along w/ tuning too.
Old Jul 10, 2012 | 04:20 PM
DirtyDaveW's Avatar
14 to 15 at idle is typcially for mine. Mild turbo cam (.571/.566 lift, 218/224 dur @ .050, 112 LSA)
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
