How Much Boost (LT1)?
Old May 1, 2009 | 11:42 PM
cody96ss's Avatar
Question How Much Boost (LT1)?
Hey all, thanks for reading. I have a pretty stock LT1 that I want to throw a Procharger on. Engine mods include 594/594 lift cam, 1.6 R/As, CC Beehive valve springs, headers w/cutouts or duals w/x pipe when cutout is closed, and a 160* thermostat. Basically, what I want to know, is how much boost is "safe boost" for my LT1? I don't want to put excessive wear on my engine, or rebuild it so I can run more boost. Thanks to all replies guys/gals.
Old May 2, 2009 | 12:28 AM
benhart21's Avatar
Not much with as high as the stock compression is. I'd be comfortable running. ~8 lbs or so with the intercooled setup.
Old May 2, 2009 | 12:35 AM
'94 Bad A Z28's Avatar
I've always been under the impression that the the stock rotating assembly could take about 12lbs of boost and 15lbs pushing the limits, but I'm not a boost guy so I have not done much research on this subject.
Old May 2, 2009 | 01:55 AM
cody96ss's Avatar
Maybe you could just sell me your blower after you get that stroker motor...
Old May 2, 2009 | 09:49 AM
user 647483's Avatar
Old May 2, 2009 | 09:53 AM
RamAir95TA's Avatar
Originally Posted by James Montigny
Old May 2, 2009 | 12:05 PM
bombebomb's Avatar
12 to 15 lbs of boost is over the limit, I would consider 5 lbs "safe".
Old May 2, 2009 | 01:00 PM
Let's move this to "Forced Induction"........
Old May 2, 2009 | 02:15 PM
<Puck>'s Avatar
If its any hint, most kits for stock rotating assemblies are 6lbs. I wont not run more then 8 intercooled on a stock engine. The high compression from the factory is not meant for boost.
These are not civic engines, 6psi with the proper heads and cam is a LOT of power with an otherwise stock LT1.
Old May 2, 2009 | 04:55 PM
My Red 93Z-28's Avatar
It seems like I remember 6-7 lbs was what many of the supercharger kits start you out at, 9 psi might be ok if you had an intercooler, but you better have a tune with it, detonation is not very kind to stock pistons. 7 psi is about a 50% gain in hp.
Old May 4, 2009 | 08:03 AM
RealQuick's Avatar
I wouldn't run any boost then.
Old May 4, 2009 | 10:53 AM
jsetzer's Avatar
No boost is the safe answer.
Old May 4, 2009 | 01:06 PM
reamo04's Avatar
QFT
you would probably be safer with a very safely setup nitrous kit than boost
Boost is a gamble time and time. You could probably run 7psi safely, i would only run 6 though on a stock setup.
Old May 4, 2009 | 01:18 PM
jsetzer's Avatar
Originally Posted by reamo04
QFT
I would def consider 150 shot (wet and tuned properly) safer than the 8-9psi a healthy lt1 would need to get to the same territory.
Throw in a cheap progressive controller to numb the initial shock a little bit and the n20 is def easier on it. But the bottle always runs out
I'm pretty close to a "stock" motor. My heads are very mild and my cam is a joke. My saving grace is nearly two full points in compression. Lets say I make 275 NA (no way to test) and so far my experiences with 7-8psi have been BORING. I would rather have my heads/cam or n20 setups again. Now an awesome motor on 8psi might be different, but stockish not so much. Honestly I would say the little t70 is a bore until @ 14psi.
Old May 4, 2009 | 02:17 PM
reamo04's Avatar
Cheap
Fast
Reliable
pick two....
