Hesitation/breakup with my turbo LT1
Old Nov 15, 2006 | 12:15 PM
Gearhead6s's Avatar
I am currently running a 355ci turbo LT1 with AFR 210cc heads, that has seen over 20psi. I am having a bit of a slight hesitation/ breakup problem when cruising. If I let off the gas, as I would to shift, then get back into it with ease or to the floor the car begins to stumble and jerk violently. I clutch in and blip the gas to a higher RPM and it stops. Data logging revels sudden changes in MAP pressure that cause a goofy A/f mix. I have replaced the MAP sensor and gasket in the intake manifold and checked all vacume ports. Immediatly after the new MAP sensor the problem seemed to fade, only to return again. Any thoughts on this issue? This only happens out of boost, as soon as it spools it pulls hard and clean. Basically its just when I am tooling around town but I will happen if I try to shift fast under boost and get back into it.
Old Nov 15, 2006 | 02:41 PM
RealQuick's Avatar
Whats your PCV setup out of curiosity? Mind giving more detailed specs on the car and any pics?
Old Nov 15, 2006 | 03:58 PM
blkchevyz's Avatar
are you running a maf sensor? if so where is it at?
can you post the data logging?
Old Nov 15, 2006 | 09:32 PM
Gearhead6s's Avatar
PCV is just the valve pushed into the grommet and vented to the atmosphere.
No MAF, speed density
I don't know how to post any of the logging but I think I can figure out how to email it.
Old Nov 15, 2006 | 11:02 PM
LT1-TA's Avatar
speed density on the LT1 pcm with boost works like **** IMHO.
Old Nov 16, 2006 | 09:25 AM
blkchevyz's Avatar
shoot it over to blkchevyz@mofbody.com
Old Nov 20, 2006 | 12:12 PM
Gearhead6s's Avatar
good thing I sold my LT1 pcm on ebay when I bought my FAST
Old Nov 20, 2006 | 03:31 PM
TransAm396's Avatar
how bout spark plug gap?? maybe its too big?
Old Nov 20, 2006 | 03:51 PM
NC-LT1's Avatar
if your PCV valve is vented to atmosphere that sounds bad to me... I would try running one with a one way check valve in it to keep boost from getting into the crank case but still maintain crank vacuum off boost.
Chris
Old Nov 21, 2006 | 10:55 PM
Gearhead6s's Avatar
Log files sent to Blkchevy, I hope you get them.
Autolite 104's gapped at .032
The PCV is in the grommet just not seeing any vac. from the engine because its not hooked back to the throttle body. Is that something that I should reconnect?
Old Nov 22, 2006 | 05:28 AM
RealQuick's Avatar
Probably a dumb question, but did you block off the port on the TB that the PCV line hooked too?
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Roadie
Feb 16, 2015 10:34 AM
blac94Z
Jan 22, 2015 11:19 PM
