help on procharger set-up
Old Jun 18, 2009 | 06:10 AM
Sporty-X's Avatar
Hello,
I知 planning to buy a supercharger set-up for my car.
I have a 1996 Camaro with an LT1 engine. The engine has already a good built but I知 now wanting more.
I plan to use the most possible parts on my actual set-up for the new one.
What I知 looking for = a new set-up to get an engine in the 650 / 700 hp range, but most of it : must be streetable with good daily driver manners. It must run on 91-octane gas.
The parts, I plan to use or re-use are :
* GOLEN short block 383 with -31cc dished pistons,
* Stock heads with Lloyd Elliot LE2 porting
* stock intake manifold
* twin 52 mm Holley throttle body
* Pace Setter long tube headers
I have an LE 1.5 cam but believe not best for what i知 looking for. Any suggestion would be great
I知 also having 31 injectors. What new size for my goals ?
Should i change damper too ?
I hope you will help me figure a complete set-up so i can already know how much money is needed to get a reliable set-up.
I also want the head unit of the blower at the place where the AIR pump was. I prefer this than having it on top of engine. If someone have an installation manual to see how it is , i would love.
Old Jun 18, 2009 | 02:59 PM
boosted-lt1's Avatar
Just a few comments to get you started:
Should be a Forged piston in 2618 alloy or 4032. 2618 is preferred over 4032 for high boost levels. You'll probably see a little more blow-by cold with the 2618 - talk to your engine builder.
Try a search within this forum if you haven't yet. There are good off the shelf grinds. You can look at Comps blower grinds.
http://www.compcams.com/DefaultWide.asp
Another option is to have a custom cam ground for your setup.
The Siemens/Mototron 60# are a good bet. They are HighZ so they will work with the stock computer without an additional converter box. Take a look at Racetronix.
A change away from the stock harmonic damper is not required and is up to you IMO. Depends if you want SFI approval.
http://www.vortechsuperchargers.com/index.php
http://www.vortechsuperchargers.com/...e=4GH218im.pdf
http://www.procharger.com/index.html
Old Jun 18, 2009 | 08:58 PM
Sporty-X's Avatar
thanks for your help.
anyone has a procharger D1SC installation manual ?
Old Jun 22, 2009 | 03:20 PM
Sporty-X's Avatar
no one has one ?
i'm interested to know what's on the twin intercooler set up and how it fit in the car.
Old Jun 22, 2009 | 07:54 PM
That Camaro Guy's Avatar
Every FI setup I've seen puts the supercharger in that location and nobody makes a kit for the top of the engine, except for home built feats of engineering awesomeness. I'd rather spend $300 to have my intake ported than buy a bigger throttle body.
Old Jun 23, 2009 | 08:38 AM
Hal Fisher's Avatar
I don't know how much a ported intake helps but larger openings on the tb works like a quick throttle on a motorcycle. Even just a small opening with the increased blade radius allows way more air in allowing for faster acceleration. It's certainly noticeable but probably doesn't add to a real increase in hp/torque.
Hal
Old Jun 23, 2009 | 10:44 AM
94SLUG's Avatar
Your stock TB and Intake will be fine depending what your hp goals are.. The twin coolers are restricted past 700rwhp....They sit under the front corners of the car... I have pics on my website...
Old Jun 24, 2009 | 07:31 AM
Sporty-X's Avatar
94slug : thanks for your pics. It helps well to see how it is mounted.
you have a complete kit from procharger ? or you mixed parts from different suppliers of parts ?
AviatorDave
Dec 19, 2016 06:35 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
95blkss
Sep 22, 2015 03:18 PM
95blkss
Jul 13, 2015 01:28 PM
jdelaprida
Jul 4, 2015 03:02 AM
