Help me choose a turbo!!
Old Feb 17, 2005 | 07:41 PM
  #31
JZ 97 SS 1500's Avatar
Re: Help me choose a turbo!!
Well it made 987rwhp/922rwtq (at 23-24psi) on one of my PTK LT1 customers. Combo is below.. at the time he was running a few lbs less boost. ~850rwhp
355 , eagle rotating assembly
JE pistons
Fully ported stock heads
Fully ported LT1 intake
CC custom turbo cam (218/218)
12 bolt rear w/3.42
Gen 6 DFI
6spd/street twin combo
Gen 1 LT1 PTK kit with 76GTS /3" downpipe
Car weight is 3680 lbs...
At 19psi with race fuel and ice in IC....
60ft-1.73
1/8th- 6.70@117.70
1/4-10.13@150.29
Car has gone 153mph with around 19-20psi.
Jose
Old Feb 17, 2005 | 10:47 PM
  #32
95Bird's Avatar
what is done to his block to be able to handle that kind of power?
Old Feb 17, 2005 | 11:59 PM
  #33
Its was orginally a 2 bolt block, then converted to splayed 4 bolts.
Jose
Old Feb 18, 2005 | 12:21 AM
  #34
95Bird's Avatar
is it filled or hard blocked or anything?
Old Feb 18, 2005 | 12:26 AM
  #35
According to the owner it was not modified anymore then the above mentioned. Of course he has not been running it for long, so we will see how long it will hold up in its current state.
Jose
Old Feb 18, 2005 | 05:08 PM
  #36
marshall93z's Avatar
is that pretty much maxed out? damn, thats alot of power for a 76mm turbo!
Old Feb 18, 2005 | 05:09 PM
  #37
and how the hell did it pick up 130+ rwhp from just a few #'s of boost? thats awesome!!!
Old Feb 18, 2005 | 06:58 PM
  #38
I was estimating around 850rwhp could be more, but with a good setup 4-5 lbs makes a good bit of difference. As for maxed out, yes, he said the boost was starting to drop off in the higher rpms. Which is typically a sign of a turbo that just can't supply any more air. I am though furnishing him with my PTE88 and my Downpipe to test with. Should be interesting to see what the kit can put down with that turbo, if the rest of the parts can hold up.
Jose
Old Feb 19, 2005 | 07:55 PM
  #39
sounds interesting!
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
