Help me choose a turbo!!
Old Feb 13, 2005 | 12:21 PM
  #16
marshall93z's Avatar
Re: Help me choose a turbo!!
Originally Posted by TransAm396
honestly i think a pte76gts would be MORE than enough for any street car..thats why i switched from a t-88..i didnt need all that top end...and i talked to jose the other day and he said a 355 with a t76 made 987(or 978..one of those)but i think 987REAR WHEEL HORSEPOWER at 23psi....now if you need more than that for a street car..theres something wrong...what the hell is someone gonna do with almost 1000rw on the streeet? good luck trying to race it and now kill yourself. not to mention it went 10.01 at 150+(tirespin)..which is good enough for me.
i thought he ran that 150 mph with 800 and some RWHP??
Old Feb 13, 2005 | 04:07 PM
  #17
JZ 97 SS 1500's Avatar
Yes, the 153mph was a lower boost setting. The 987rwhp setting has not made a track run yet.
Old Feb 13, 2005 | 04:41 PM
  #18
Eric Bazan's Avatar
Man, Turbo head units (turbos kits in general) are expensive! $1500 for a PTE76GTS, whew! I would like a turbo set up. But, I guess I have a lot of saving to do. $4600 for just the kit from PTK and $1500 for the turbo. Thats a lot of MOOLA! I guess I'll have to stick with my T-trim vortech for now.
Eric B
Old Feb 13, 2005 | 05:54 PM
  #19
mongse_1's Avatar
The GTS is pretty expensive. For the results you get though....
Old Feb 13, 2005 | 05:56 PM
  #20
TransAm396's Avatar
yeap....my point exactly..it hasnt ran with the other setting yet...i think its going to be more than double enough for any street car
Old Feb 13, 2005 | 08:21 PM
  #21
Geoff Chadwick's Avatar
My thoughts are the same. Even 12psi on a Vortech is enough for a street car.
Even 600rwhp is a LOT on the street, espicially if you run normal street tires.
Jose is alive!
Old Feb 13, 2005 | 09:09 PM
  #22
97WS6SCharged's Avatar
Jose is alive!
Exactly, if you punch it, even at speed, the car had better track dead straight or you'll be cleaning out your shorts at the very least.
I haven't seen Jose in a while either.
Old Feb 13, 2005 | 09:37 PM
  #23
http://www.racelogic.co.uk/traction/
Someone on the forums has their setup. From everything I've read it's the top choice for high end TCS systems. It's extremely expensive, but imagine what it'd do to a street turbo car...
Old Feb 14, 2005 | 03:47 PM
  #24
so the 76GTS, which is good for 1100 hp, will make near 1000 to the tires? DAMN!!! thats a bad little unit!
Old Feb 14, 2005 | 04:23 PM
  #25
While we were away in Puerto Rico we did some testing down there, a rotary powered suzuki samuri made 1098rwhp with it. Of course that is at optimal PR, but it goes to show the 1100 crank rating is conservative. Several Supra's have made 990+rwhp with the unit as well.
Jose
Old Feb 15, 2005 | 03:37 PM
  #26
damn...nice unit! lol!
Old Feb 16, 2005 | 06:00 AM
  #27
Live for TAs's Avatar
Cool Re: Help me choose a turbo!!
That does look appealing. I did the US$ conversion & also looked at their US dealer:
5 way generic unit: UK # 645= $1215, US retailer price <$995 (you have to email for the price).
Originally Posted by Racelogic website
On a turbo car, if the launch control is active, and full throttle is given for two to three seconds, the boost pressure will build up before the clutch is released, resulting in stunning off-the-line performance.
Could be the best thing from across the pond since the V12 XKE!
As for the original question, I ran your estimated numbers in my turbo calc program:
383 CID
430 Base HP
80% engine efficiency
65% turbo efficiency
70% IC efficiency
90 degrees ambient
1 PSI inlet drop
2 PSI IC drop
Sea level
Min 6 PSI @ 2K RPM, Max 17 PSI @ 6K RPM
FWHP: 821
The GT42 56 trim, a Holset HX40W, or a T72 will all work in this application from 2K-6K RPM.
Old Feb 16, 2005 | 08:05 AM
  #28
Jose
Is there a website or something for that? I've got a friend that's a die-hard Samurai fan, and another that's a die hard rotary fan.
Old Feb 16, 2005 | 09:36 AM
  #29
No, no website for that. Actually most of the info they don't want out in the public. They do a good bit of mud racing, and looks like their is lots of money involved...lol. I just wanted to at least get out to the public, that the GTS is way underrated.
Jose
Old Feb 17, 2005 | 04:32 PM
  #30
so, what do you think it would make on a v8? being a bigger motor and all...
