header pics from TT and single turbo lt1 setups
Old Feb 8, 2007 | 10:54 PM
CCCCCYA's Avatar
I would like to see some header pics from TT and single turbo lt1 guys. I'm getting prepared to turn my stroker 383 into a TT setup and would like to see how you guys have fabbed up the headers and other hot parts. I'm especially interested in how you routed the exhaust from the turbo outlet back. I can pretty well picture the headers swept forward, but I'm having a difficult time visualizing the downpipe routing while still being able to change plugs..
Help me out fellas..
Dave C.
Old Feb 9, 2007 | 10:50 AM
Roadie's Avatar
mine looks something like this.
Jon (RealQuick) was responsible for building it.
Old Feb 9, 2007 | 11:05 AM
RealQuick's Avatar
Holy big picture batman!!!!!!!
Old Feb 9, 2007 | 11:13 AM
RealQuick's Avatar
log kit 1 was Jered's kit (Roadie)
log kit 2:
Cast Manifold 1:
Cast Manifold Kit 2:
Old Feb 9, 2007 | 12:35 PM
ddj19852003's Avatar
You guys setups are sick! How much does that manifold setup cost you guys?
Old Feb 9, 2007 | 12:44 PM
RealQuick's Avatar
Its free if ya have all the materials laying around and you can weld some pipes together
Old Feb 9, 2007 | 12:54 PM
Free, I wish I was as skilled . Im thinking about adding boost to my LT1. Right now I have a 355 it makes good power but I want a little more. How conservative are you guys engines to run the turbos. Like compression and what not?
because I have forged probe pistons .030, 6" scat i beam rods, Scat crank, 2 bolt studded, double roller timing chain conversion but my cr is 11:1 could I run boost or would I have to change a few things first?
Old Feb 9, 2007 | 01:16 PM
RealQuick's Avatar
At 11:1 CR, you would want to stay under 6psi... probaly 4-5psi realisticly. You need to get your compression down. If you are running stock LT1 ported heads, then your combustion chmber is probably ~54-56cc, so a set of AFR heads with 74cc (or is it 72cc). That will help.
Old Feb 9, 2007 | 01:34 PM
Roadie's Avatar
My engine is an all forged 355, 8.65:1 with competition port trickflow heads flowing 301.x/221.x @ .600 on 2 different benches. I plan to push a T-76 Q trim to it's limit (the .81 a/r turbine housing is probably the bottleneck in my setup).
Old Feb 9, 2007 | 01:59 PM
RealQuick's Avatar
Just give me the word and I'll send ya the .96 to try...
Old Feb 9, 2007 | 04:40 PM
CCCCCYA's Avatar
Thanks for the pics fellas. This does indeed give me a little better idea of routing. I was thinking about routing like the old GN's, but wasn't sure how well it would work out, hence the twins idea instead of one big single.
Thanks again for the pics so far. Keep em coming
Dave C.
Old Feb 10, 2007 | 10:41 AM
will62085's Avatar
see my car domain site in my sig.
Old Feb 10, 2007 | 11:10 PM
CCCCCYA's Avatar
You wouldn't happen to have hi res version of the pics on your cardomain site or any other pics of the install would you? It's almost exactly what I'm planning on doing. I'm planning on using a F.A.S.T. ecu though, otherwise VERY similar.
Thanks -
Old Feb 11, 2007 | 04:05 PM
TransAm396's Avatar
your car is amazing.
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jun 23, 2016 08:42 PM
ddr698
Jan 9, 2015 10:05 AM
limige
Aug 17, 2002 12:15 PM
