Head Gaskets for 9 lbs. of Boost
Old May 28, 2003 | 12:02 AM
SlimZR28's Avatar
I did a recent rebuild and I had recieved some advice from a machine shop that the stock head gasket made by felpro would be okay. Well, I installed them on my 355 LT1 with 9 lbs. of boost and as soon as I started the dang thing it seems to be leaking oil, I thought it was the intake or the oil pressure sending unit, but I think that it is comming from the passenger side head gasket. Anyone have any experience on these problems? Let me know. Thanks
-Slim
Old May 28, 2003 | 12:16 AM
RCF925's Avatar
I wouldn't use stock Felpro gaskets with 9lbs boost. They make a set with copper rings for the cylinders for high compression motors.
Old May 28, 2003 | 11:30 AM
SlimZR28's Avatar
Any idea where to get a quote on some?
-Slim
Old May 28, 2003 | 11:55 AM
95 Silver TA's Avatar
I used Felpro 1074 Gaskets. They have the copper ring with .039 thickness but is stronger than the Lt1 stock replacement head gaskets.
I believe I got them from summit.
Hope that helps,
Claude
Old May 28, 2003 | 12:14 PM
rskrause's Avatar
Moderator
I am using Felpro #1074 as are most others.
Rich Krause
Old May 28, 2003 | 07:04 PM
SMOKNZ's Avatar
I just switched over to the 1074's after blowing the stock Felpro ones. They were around $35 each from summit, and get some ARP bolts too.
Old May 28, 2003 | 11:55 PM
Wild1's Avatar
That brings up a good question. At what point (boost) does one ring the heads for ringed head gaskets.
I'm not familiar with the terms but it is when the machine shop cuts rings into the cylinder heads for the head gaskets...
Old May 29, 2003 | 06:20 AM
SMOKNZ's Avatar
There was a thread on this exact topic about 2 weeks ago or so. The consensus was that o-ringing isn't really needed. The 1074 or the comedic head gasket with ARP studs or bolts will be sufficient up to very high boost levels.
I run 16 psi on my setup, it was the stock Felpro gasket and TTY bolts, that didn't work to well, Now the 1074 and ARP bolts.
Old May 29, 2003 | 09:52 AM
Wild1's Avatar
Thanks, I'll do a search. I've been poking into this forum periodically, I must have missed it before.
Old May 29, 2003 | 02:03 PM
SlimZR28's Avatar
I am running stock replacement head gaskets and some arp head bolts, do you think that I need to switch to the 1074's?
-Slim
Old May 29, 2003 | 03:52 PM
SMOKNZ's Avatar
I wouldn't change it unless it lets go. Mine went because the TTY bolts stretched. All the shorter ones around the spark plugs were not very tight when i disassembled the heads. The ARP's may help that gasket live a little longer.
Old May 30, 2003 | 12:25 AM
stubbs's Avatar
TPIS has gaskets with a stronger "squelch" area just for boosted vehicles, check it out.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
