got dyno tuned
Old Feb 25, 2008 | 08:32 PM
  #16
antoine's Avatar
the guy who did the tune has been tuning for 12 years,advance dyno did not tune my car it was the guy mark he is from sac.
Old Feb 25, 2008 | 08:44 PM
  #17
SiDeWaYZz28's Avatar
wheres Mark shop in sac?
Old Feb 25, 2008 | 10:06 PM
  #18
antoine's Avatar
Here is your dyno graph from saturday, the blue was the first run and the
red was the last run.
Old Feb 26, 2008 | 08:29 AM
  #19
jsetzer's Avatar
Belt slip or pressure leak? Does it hold boost all the way up?
Looks like it was doing good @ 4.25 and on the blue run even up to about 4.75 but kept falling on its face.
I know the tpi won't be a high rpm monster... but that don't look right.
Old Feb 26, 2008 | 10:20 AM
  #20
cause4panic's Avatar
I would also say belt slippage/pressure loss.
i would recheck the rockers, take the distributer back out and make sure its not a tooth off.
Old Feb 26, 2008 | 11:38 AM
  #21
antoine's Avatar
will check the rockers and belt.
Old Feb 26, 2008 | 04:22 PM
  #22
boosted-lt1's Avatar
That motor should pull pretty linear to 6000rpm. You've definitely got some issues.
It doesn't just flatten, but falls hard with rpm and you're losing 100hp in the last 1000rpm when you should be gaining that!
Valve float? I don't think this is a tuning issue.
Last edited by boosted-lt1; Feb 26, 2008 at 04:32 PM. Reason: Looked at A/F ratio again
Old Feb 26, 2008 | 08:45 PM
  #23
antoine's Avatar
i hope it's not valve float in those heads
Old Feb 27, 2008 | 05:46 AM
  #24
fuel pump? tape a guage to the windsheild and go for a ride
Old Feb 27, 2008 | 01:06 PM
  #25
antoine's Avatar
where should the fuel pressure be at.
Old Feb 27, 2008 | 01:26 PM
  #26
Sparkz28ss's Avatar
45psi or so @ idle... you may want a 1:1 rise with boost psi
Old Feb 27, 2008 | 04:28 PM
  #27
roguedriver's Avatar
If it were fuel pump (or lack of), you'd be leaning out on the top end. Your A/F's on your dyno chart stay pretty solid through the pull, so the fuel is there. Now when you get your issue fixed and you bring that top end power back, i'd keep a close eye on the A/F's then, cause at that point, it might start leaning out once it makes the power again that it should be. I'm with the majority here. Seems like belt slippage. You have a boost gauge? Whats your boost through the pull? See any belt dust around the head unit pulley?
Ken R.
RallyRed701/2
Jul 27, 2015 02:55 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
