Good IAT temps?
Old Oct 21, 2007 | 02:46 PM
blown69nova's Avatar
Good IAT temps?
What is an average temp at 18psi (cent. blower)? I'm seeing 165-175 degrees with ambient around 70.
Thanks, Steve
Old Oct 21, 2007 | 02:58 PM
Sparkz28ss's Avatar
intercooler or no?
sounds like no IC
Old Oct 21, 2007 | 10:35 PM
Intercooler.
What would be reasonable?
Steve
Old Oct 22, 2007 | 12:01 PM
Sparkz28ss's Avatar
Originally Posted by blown69nova
Intercooler.
Steve
Where is your IC located?
I would think that you would be a little lower then that.Not that the mid 170s is that hot,but it does sound a little warm .But to be fair 18psi is a good amount of boost.A friend of mine was running 10psi out of his T trim and it was around 225deg without an IC, so I think you could get the temps down.
When I run around 12psi on a 74deg day my IAC at the end of the run is around 113deg.Im using a 2 core ATI intercooler in the nose so it gets a good amount of air moving past it....also made an IC sprayer from some leftover n2o parts I had laying around just incase I need to drop the temps a little more.
Old Oct 22, 2007 | 05:19 PM
I talked to Procharger today, and they said my temps were on the low side. He told me my discharge temps were probably in the low 300 range @ 18 psi.
Thanks, Steve
Old Oct 22, 2007 | 10:12 PM
sc68z28's Avatar
Steve, this turns out to be a hard question, at least for me to answer.
I pulled up some datalogs and took a look at 6 of them, the IAT's were all over the place.
Here is what I saw on 3 of them.
On one, 2 min data log, I did on the street. I noted it was a 70* day, IAT's were 98* to 101* cruising and at WOT, (2nd thru 4th) climbed to 141* w/16# boost.
The next log was done at an 1/8 mile track. By the time I staged, IAT's were 117* and went to 187* @ 16.5# boost. 85 degree day. And was climbing fast, a few more seconds it would have been at 200*
The last log is the first pass, on the vidio in my sig (1/8 mile). I was using a larger pulley, and the belt was slipping that night, only saw 9# boost. The air temp was 94 degrees, after the burnout AIT's were 131* and went up to 161*
So there must be a lot of variables that effect IAT's.
I think at a 1/4 mile track, after doing a burn out and the run, IAT's could be over 210* on a 75 degree day w/18#'s boost.
My IC is a Procharger 3 core race, up front. See pic
---Bill.
Old Oct 23, 2007 | 08:05 AM
97WS6Pilot's Avatar
Those 3 core race intercoolers flow really well but don't cool as well as the 4 inch crossflow FMIC alot of guys use. I think your intercooler will flow better than mine but doesn't cool as much. That being said I would take cfm over Iat's if mine was a race car.
My IAT's never get above 150 in a quarter mile run at 15 psi on a 95 degree day. Of course I'm spraying a bunch of meth too which is not measured by the iat sensor so actual is probably alot lower.
BTW I really like that picture of your Z28.
Old Oct 23, 2007 | 05:02 PM
My temps were pretty consistent, run to run (1/4 mi.).
My buddy has a turbo car, and at 25 psi (1/4 mi) he sees 150 degrees or so. He has an air/air that is the biggest I've seen (next to a semi). Not sure if it's 3 or 4", but is just about headlight to headlight on a 84 Cutlass!
Steve
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Feb 13, 2015 03:09 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
