Good or Bad
Good or Bad
I found some blower pistons for a 355 and was wondering if they were any good and if the rings they came with were any good. Here is the specs: forged, -20.3cc dish Probe FPS series w/ Total Seal Classic Race Rings. They are only $359 for the set of pistons and rings. http://www.cnc-motorsports.com/prod...7408&CtgID=7124
Tell me what you think.
Re: Good or Bad
I found on CHP motorsports that they replaced the trw pistons that's why they have the same PN. Also they are 498 grams. That's not too bad, huh? Also this is from flatlander racing:
Chevy 350-5.7 Rod - Dish Top
Ring Grooves: 5/64, 5/64, 3/16
Dish Volume: 20.3cc
Stroke | Rod | C/H | Bore | Weight | Comp Ratio computed w/.010 deck & .038 head gasket | Part # | Price/Set
.................................................. .....58.0cc...........64.0cc .........68.0cc.........76.0cc
3.480 -5.700 --1.560 --4.000 --486 ------8.75 ---------8.26 ---------7.97 --------7.46 ........P2441F-STD $329
4.030 ..................................498 ------8.86--------- 8.37 ---------8.07 --------7.55 ........P2441F-030 $329
4.040 ..................................504 ------8.89 ---------8.40 ---------8.10------- 7.58 .........P2441F-040 $329
4.060 ..................................513 ------8.96 ---------8.47 ---------8.17------- 7.64......... P2441F-060 $329
Dish Volume: 20.3cc
Re: Good or Bad
hey man, when you get your set up figured out let me know what youve done. im trying to build a budget blower 355 too....
if i find something good ill let you know too....
did you see that summit kit i posted on your other thread? i hope to find a total kit with gaskets, seals, bearing....the hole shot to make it simple...
kizz
18
Mar 16, 2004 10:41 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
