go with cometic or felpro 1074
Old Nov 26, 2004 | 03:34 PM
Seal's Avatar
Which one should I go for? I've heard cometic u can hold some good boost/high hp, but they cost a bit more...
then there is felpro 1074, which is a bit cheaper but do a very good job as well...
so which should I go for?
this is for a turbo LT1 boosting around 10psi, and around 15psi in the future (once i upgrade the drivetrain and get GT67 which will be like next year)
Old Nov 26, 2004 | 06:07 PM
Brady's Avatar
Re: go with cometic or felpro 1074
Fel Pro should be fine with those boost numbers.. I switched to Cometics at around 20# boost, only because the heads were lifting. I switched to studs and cometics and no more problems.
Old Nov 26, 2004 | 07:22 PM
Seal's Avatar
yeah, the new motor i'm getting built has studs...
so felpros will be fine with studs?
Old Nov 26, 2004 | 07:25 PM
texlurch's Avatar
Should be fine. I've seen a little over 16 psi on mine with FelPro's and ARP head bolts (not studs)
Old Nov 27, 2004 | 03:14 PM
sleeperz28's Avatar
I have run 22psi with head studs and felpro's with no problems.
Old Nov 27, 2004 | 04:41 PM
'68LT1camaro's Avatar
I'm not running a turbo, but I'm making 11psi with my Vortech S-trim, and haven't had any problems with FelPro's. I do use ARP head studs.
I'm not gonna buy expensive gaskets if I don't have to.
Old Nov 28, 2004 | 08:34 AM
john35thss's Avatar
The cost difference between cometics and felpro 1074 is only a few dollors. The cometics are reusable but need a very smooth surface to work well.
Using them on both the 396 lt1 and 3.8 GN buick I'm building so I won't know how well they work till next year.
John
Old Nov 28, 2004 | 12:04 PM
tjwong's Avatar
Expensive?? Isn't it even more expensive if you have to do the job again not to mention parts damage. I would spend the extra few dollars for the best gasket available.
Old Nov 29, 2004 | 01:00 AM
Seal's Avatar
price diff is like 20 bux each gasket i believe?
Old Dec 1, 2004 | 10:41 AM
N20Dave's Avatar
Has anyone experienced any coolant leaking issues with the cometics?
Old Dec 1, 2004 | 10:53 AM
mn_vette's Avatar
no coolant leaking but I did get oil leaking from them. I think it's because I didn't have the block super shiny clean before I installed them.
Old Dec 1, 2004 | 01:06 PM
I agree TJ, to an extent. DETONATION is usually the culprit when head gaskets let go in a supercharged "street" engine. With proper engine assembly, and good tuning, blowing a head gasket is rare. Besides that, FelPro does make good quality gaskets.
Old Dec 1, 2004 | 01:10 PM
Gimpster's Avatar
sometimes blowing a HG isnt a bad thing either IMO. I've had a coupe motors where I wish it had blown a HG first before grenading a piston or two.... or three .. etc
Old Dec 1, 2004 | 07:29 PM
lunapark's Avatar
Yes, the heads were loose and I was blowing boost into the cooling system
Old Dec 3, 2004 | 07:26 PM
arnie's Avatar
Shame on you, Brady. You changed two variables at one time. To me, not a valid 'thumbs up' for cometics.
