Gapless rings for a supercharged engine?
What do you guys think of using a gapless ring on a supercharged engine? I have heard good and bad about them for an n/a application. Seems like they might be a good thing to none of the boost turns into blow by.
i have read several articles saying they definately make an increase over conventional rings. the key is where the placement of the gapless ring is. on a superchargered or NOS car, the combustion chamber can be much hotter than n/a, therefore, you should not use top ring gapless in this application, but they do make a gapless second ring. n/a cars can run a gapless top ring.
i put a gapless total seal 2nd ring set in my 69Z and it will see 15+ boost on a 383.
hope that helps.
mike
hope that helps.
mike
from the experiences i have read about and talked to people who have actually run them the experiences have usually gone like this (whether n/a or fi mind you)
initial impressions:
great, love them, seem to work well
median results:
starting to have some issues, not sure if rings are the issue
end results:
rings became an issue, had to be changed
Some people argue most of the experiences are caused from the wrong type of honing finish on the bores and/or wrong application/installation BUT i argue if they need to have things so perfect for them to work, is that really going to be possible for a street motor?
i went with plasma moly top ring
median results:
end results:
We are talking real subtle stuff here. On the order of a few hp either way. In that light, I don't think that zero gap rings are worth the potential problems. There is potential "free" hp here, but I am not convinced they work anyway. Clearly, there is leass leakdown with a cold motor and gapless rings. But if you have "traditional" rings, properly installed, and up to operating temperature I think the difference, if any, is very small.
All this is anecdote, as I have never used them.
Rich Krause
Rich Krause
Thanks for the replies. I guess I will just stick with the speed pro race rings. I tried gapless once before but could not really tell how good they worked since I had 2 broken oil controle rings.
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
