Fuel question
Old Jul 27, 2005 | 05:20 AM
wicked_95z's Avatar
Fuel question
Engine is a 383 @ 9.0:1 with LE3 LT4 heads and just about everything else and I will be running a P-1Sc @ about 6-8 lbs. I have a racetronix kit already installed with 50# inj. and I was curious if I should go ahead and install the ATI in-line pump.
Old Jul 27, 2005 | 11:39 PM
breakmyfootoff's Avatar
Re: Fuel question
You can never have too much fuel supply.
Old Jul 28, 2005 | 12:08 AM
markinkc69z's Avatar
Re: Fuel question
If you are expecting 600 hp or less, and I assume you are, and have the high pressure 255lph pump then no. Your setup will be fine.
Old Jul 28, 2005 | 05:21 AM
wicked_95z's Avatar
Re: Fuel question
Well I was hoping and told by the engine builder I could see over 600hp
Old Jul 28, 2005 | 11:56 AM
Re: Fuel question
Then I would suggest a more suitable pump that can support the power. Believe what ATI tells you.
Old Jul 29, 2005 | 05:10 AM
wicked_95z's Avatar
Re: Fuel question
Are you talking about twin 255's or something else
Old Jul 29, 2005 | 08:44 AM
Re: Fuel question
A good single inline pump will get the job done, or you may install the supplemental pump ATI has for the kit.
Old Jul 29, 2005 | 09:02 AM
z96's Avatar
z96
Re: Fuel question
I Would Say Racetronix Pump And A Set Of 60 # Motron Injectors
With A Good Tune Can Handle Over 600 Hp
Deadbolt24
Jan 19, 2015 01:29 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
dansam
Jul 20, 2002 01:10 PM
