fuel pumps ... what are you using?
Old Aug 20, 2006 | 10:44 PM
  #16
TransAm396's Avatar
Re: fuel pumps ... what are you using?
what if i went with JUST the racetronix? would I be in danger? Like i said..650 max..if i hit 600rw ill be happy..ill prolly only run 8-10psi on the street.
Old Aug 20, 2006 | 11:21 PM
  #17
T/A KID's Avatar
You'll be fine, call ractronix tomarrow and talk to them. They actually recommend this setup to 700RWHP.
just get the racetronix dual walbro setup from lonnies
I would go that route if you decided to make 1000 RWHP. Plus I think It would be more pricey as well, and the Fab work is a Bitch (I think anyways)
The racetronix kit comes with a Plug-n-play connector to work with the KB or MSD boost a pump.
Your looking at $250 for the racetronix kit, $200-240 for the boost a pump (I think, can't remember) and $420 for the 60lb motrons from speedinc.
Old Aug 20, 2006 | 11:24 PM
  #18
TransAm396's Avatar
Ok..well I figure I can go with just the race tronix pump kit while IM on low boost breaking in the engine..and by that time buy the BAP. Plus i need an aeromotive AFPR no?
Old Aug 20, 2006 | 11:30 PM
  #19
T/A KID's Avatar
no
To be honest Probably not, I plan on doing it though just b/c I don't like using parts with a 130,000 miles Plus, you know what I mean, lol
Old Aug 20, 2006 | 11:48 PM
  #20
TransAm396's Avatar
do I want hiZ or loZ(daily driver)
Old Aug 21, 2006 | 11:39 AM
  #21
T/A man's Avatar
Im using a bosch inline pump with 30lbs/hr injectors. Works very well, no lean issues on the dyno at all.
Old Aug 21, 2006 | 01:08 PM
  #22
Roadie's Avatar
The stock PCM will only drive high impedence injectors, but you can't get BIG injectors (75lb/hr and higher) in high impedence.
If anyone needs an acceleronics impedence converter box to convert the hiZ PCM signals to work with lowZ injectors, I'll sell one for $225 shipped. I bought it for the same price used and never did install it because I went a different route. (They go for $400ish new)
Old Aug 21, 2006 | 01:10 PM
  #23
97WS6Pilot's Avatar
Originally Posted by bowtiepwr
>I have the Walbro 255 340m intank and Vortech inline.
I want the Weldon, but which and is there anything wrong with the Barry Grant King Sumo pump? I know someone here had a bad experiance.
Dual intanks is the way to go. Not only does it support more HP but it also gives you a backup limp home pump. I have a switch on mine so I can switch between primary and secondary pumps. My secondary comes on at 5 psi. I have 15000 daily driven miles on this setup and I would highly recommend it. Lonnies setup is a good deal when you look at all the shopping and soldering you have to do to make one yourself.
I had a fuel pump fail on me 3 yrs ago 100 miles from my house in the middle of nowhere. I wish I would have had this setup then. I had to lowboy my car home.
Old Aug 21, 2006 | 02:53 PM
  #24
TransAm396's Avatar
Will 60lbs hiZ's be a problem on my car with the stock PCM?
Old Aug 21, 2006 | 04:31 PM
  #25
97WS6Pilot's Avatar
The mototron 60's are plug and play with the stock computer and have a nice spray pattern for good low rpm and idle. Racetronix and Harris Speed Works sells flowmatched sets.
Old Aug 22, 2006 | 11:12 AM
  #26
CALL911's Avatar
how much did it cost to make the kit?
All said and done I think I spent about $400 on everything. I ended up making some chages though. At first I used a Y-block from Jegs, but when my rubber hoses kept falling off I found it a royal pain to pull the pumps out with the Y-block, so I just went to a local hardware store and bought some plumbing instead that was smaller and fit much better. And I also swapped to braded fuel lines in the tank.
BTW, I am running 60lb mototron injectors. I HIGHLY reccomend them after talking to mulitple tuners. These should support up to 750-800 at the wheels.
Old Aug 22, 2006 | 03:09 PM
  #27
mzgp5x's Avatar
Using (2) Walbro 255 intank FP's. With Kenney Bell voltage boost on Pump #1Each pump on seperate circuit. Pump #2 can be shut off from switch near drivers seat. All 3/8 socketless hose. Runs to a Y @ mid car to 1/2 line to fuel cooler/ fuel filter/ then to rail. Running 72# injectors with the acceleronics driver. So far this works well for me. No fuel starvation.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
