Fuel pump booster location
Getting ready to do some plumbing underneath the car for the turbo install, and have ordered the MSD 2350 fuel pump booster & Racetronix LT1 fuel pump harness. Is there an ideal location for the booster? Inside or under the car? Where is everyone mounting theirs? The Racetronix harness is listed as being plug & play w/ this unit, so I'm looking for feedback from anyone that has this combo.
Re: Fuel pump booster location
The MSD 2350 is a voltage control box, not a booster pump- sorry, should have made that clear, was parts shopping all day (found it for $200 shipped BTW
, everywhere else was like $235+ and plus shipping) & figured everyone knew about this unit.
The under seat idea sounds good since right in front of there (under the car by the fuel filter) is where I'm installing my oil return pump & there is a protected area where the seat mounts that I can run wires & vacuum hose to under the car.
, everywhere else was like $235+ and plus shipping) & figured everyone knew about this unit.The under seat idea sounds good since right in front of there (under the car by the fuel filter) is where I'm installing my oil return pump & there is a protected area where the seat mounts that I can run wires & vacuum hose to under the car.
http://www.racetronix.com/product/RX...FPWHG-2-PB.jpg
Thanks for the pic, I looked at the wrong vendor for the harness initially & then got it @ Thunder Racing.
From the looks of that pic, it will need to be fairly close to the pump connection.
Originally Posted by Racetronix
Correct, behind the back seat is fine. Install the extra connector set supplied with your Racetronix system onto the MSD power in and out wires. The ground(s) are common to the body and can be located in the same spot as the relay + harness ground. Keep the wires reasonably short. Set the MSD unit for max. 17V under WOT.
As you probably know on the msd bap there is a black ground wire and a yellow wire on one side and on the opposite side is a red and black wire marked -pump and +pump.
Originally Posted by ProchargedLT1
When you say the msd power in do you mean the yellow wire with the 30 amp fuse? and the power out is the red wire that is marked +pump?
As you probably know on the msd bap there is a black ground wire and a yellow wire on one side and on the opposite side is a red and black wire marked -pump and +pump.Thanks
Thanks for the reply.
So solder the supplied connectors on?
I dropped the tank so i could flush it..is there any special way to flush it? Or is it as simple as putting some fresh fuel in it and then "flushing" it back out?
Can you run the Racetronix harness inside the car , all of it....and just go through the fire wall fpr the alt hook up....?
anyone have pics of all this installed
