Fuel Injectors...
Re: Fuel Injectors...
500hp with 48# injectors? are you nuts?
stock 28#'s are good up to about 400 hp.. i'm sure 48#'s gotta be good for 600-700.
somewhere there is a table/calculator on how much hp an injector will support, anyone know where to find this? i need it too!
He said 42#'s and it is also FI and rwhp also. My 48#s are 85 to 90% DC at 420 rwhp.
http://www.smokemup.com/auto_math/fuel_injector.php
http://www.smokemup.com/auto_math/fuel_injector2.php
For instance:
Injector Flow Rate: 42 lb/hr @ 39 psi
New Fuel Pressure: 43.5
Number of Cylinders: 8
Brake Specific Fuel Consumption (BSFC)0.55
Result:
Duty Cyle Max HP @ Duty Cycle
80% 516.65 HP
85% 548.95 HP
90% 581.24 HP
95% 613.53 HP
100% 645.82 HP
I'm running 30lb injector's with my ATI 600b at 8lbs..... It dyno'd 451 RWHP & 438 RWTQ. No FMU, running 58 psi with the vacuum line on and programming to allow this.
Yes, i run almost 100 percent DC at 6000 rpm, but i don't spend much time there and they don't lock up or overheat.
That sounds about right... 58psi fp is the key to that combo.
Injector Flow Rate: 30 lb/hr @ 39 psi
New Fuel Pressure: 58
Result:
80% 425.89 HP
85% 452.51 HP
90% 479.13 HP
95% 505.75 HP
100% 532.36 HP
Result:
80% 425.89 HP
85% 452.51 HP
90% 479.13 HP
95% 505.75 HP
100% 532.36 HP
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
