Front mount intercooler question.
Old Mar 29, 2006 | 02:26 PM
CALL911's Avatar
I am planning on running either a 3 or 4 inch front mount intercooler on my supercharged 95 Z. My question is, will it recieve enough air through the front bumber behind the fog lights? Or do I have to cut up the front bumber to have enough air flow here. Obviously more air flow will be attained with cutting into the bumber, I am just looking at if it will work without doing any cutting.
Old Mar 29, 2006 | 02:55 PM
Formula_one's Avatar
Re: Front mount intercooler question.
If you pull out the front bumper support that's behind the bumber it can be done.. But why not create more airflow? The cooler it gets the better! I'd rather cut the front bumper than pull out or cut the bumper support inside.
Old Mar 30, 2006 | 04:07 PM
CALL911's Avatar
I'd like to keep the front bumber as "stock" looking as possible, and not have to see my intercooler through the front if possible. If not enough airflow can get through, then I will have to do some cutting, but I would rather not if I don't have to.
Old Mar 30, 2006 | 09:10 PM
bowtiepwr's Avatar
>I posted this earlier in this section ...
"has anyone looked into LS1Speed http://www.ls1speed.com/catagory.cfm...ed%20Induction their Griffin intercooler their part # GRICS-000AE-3"
Old Mar 30, 2006 | 10:21 PM
Procharged94Lt1's Avatar
I would say cut the bumper to allow the airflow, but put a grill over it to hid the intercooler. You could also spray the intercooler black to help hide it behind the grill.
Old Mar 30, 2006 | 10:25 PM
You're gonna have to cut something. Might as well let it be the bumper cover if you want to keep the support. Do a search, there are quite a few pics I found when I was looking to build my own kit. Just have to do the research and figure out which you like best.
Old Mar 31, 2006 | 12:52 AM
Chrisbequick's Avatar
It won't recieve enough airflow for efficient cooling unless you open up the grille. The problem is that if you cut the grille you also have to cut the bumper support. Here's mine:
-Chris
Old Apr 5, 2006 | 10:11 AM
CALL911's Avatar
Is there a plastic peice out there that is made to possibly direct/funnel up air to the intercooler from the bottom? Maybe one that doesn't hang too far down to cut off all airflow to the radiator, but just enough to scoop up some air flow to the intercooler, and leave enough air flow to the radiator to properly cool the motor as well? If not, this would be a good opertunity for a company to make something.
Old Apr 6, 2006 | 09:00 PM
NOMAD's Avatar
I'm using NACA ducts like on NASCAR cars and 3" ducting to pull air from the bottom sides of the nose and flow it over to the intercooler.
I haven't tried it yet, so i'm not sure how efficient it is, but I too don't want to hack the front end.
-Shannon
Old Apr 7, 2006 | 06:32 AM
1st and goal's Avatar
Here's how I did mine.....
www.geocities.com/marc94z/intercooler.html
Marc
Old Apr 7, 2006 | 08:02 AM
CALL911's Avatar
-Shannon
Do you have any pics of the NACA ducts? Will they be noticable from the outside of your car when they are installed?
Old Apr 7, 2006 | 09:53 AM
NOMAD's Avatar
I dont have any pics because I dont have the front end on yet. I'm making a tubular crash area like the one BMR made. You will not be able to see them from the outside as they will be drawing air from the bottom of the nose.
-Shannon
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
96SilverRam
May 5, 2015 09:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
