Is this the fastest Lt1?
Old Nov 22, 2004 | 07:30 PM
  #31
meengreen 94z's Avatar
Re: Is this the fastest Lt1?
Originally Posted by lt4 fd
wait that 8.2 ls1 has a stock block AND STOCK CRANK.... thats one hell of a feat.
Yeah the LS1 crank seems to be a pretty good peice.Alot of that car is suspension though, Im not sure how much power its putting down but Id guess 850-950rwhp
Old Nov 24, 2004 | 11:14 AM
  #32
Guido's Avatar
Originally Posted by meengreen 94z
Rick Heads car is a 3rd gen I believe
It is. There are some pics and vids of it on the BMR webpage as it uses a lot of off the shelf BMR parts.
www.bmrfabrication.com
Old Nov 24, 2004 | 01:14 PM
  #33
neil350's Avatar
Originally Posted by Fast Caddie
Interesting he used a 398, i figured he would go with a 355 or something for more strength. Thicker cylinder walls and less mean piston speed should make the whole setup stonger. What rpm is(was) he running it up to? And what max boost is he hitting?
This is the same motor he had in his old dope set up that went 9.38@149, just different pistons and cam.
Old Nov 26, 2004 | 12:49 PM
  #34
chucks97ss's Avatar
Try 8400 and 23psi. Changed gears so we wouldn't have to spin it as high, but then the bearings went out. Probably from when the first turbo went out at thunder and put metal through the motor. New motor in the works, this car WILL run 7's next season. Any LS1's scared yet?? 2005 is going to be a very interesting year for LT1's and LS1's.
Later,
Chuck
Old Nov 26, 2004 | 06:03 PM
  #35
lt4 fd's Avatar
Daaaaaaaamn!!!
blown94
May 3, 2015 12:48 AM
alphaauto
Jan 23, 2015 07:42 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Ken95Z28
Aug 21, 2002 04:32 PM
