engine break in
Old Jan 30, 2008 | 06:10 PM
personoo's Avatar
engine break in
I have a 400 sb chevy that just been rebuilt and i was wondering the correct break in procedure before i can boost this engine.
the engine has 8.5 compression,J&E pistons afr 210 heads,totalseal stainless steel rings,the old fast fuel injection,oliver billet rods,callies crankand twin 67mm turbos.
Old Apr 10, 2008 | 08:50 AM
c0rey's Avatar
Wondering the same.
Old Apr 10, 2008 | 09:25 AM
jsetzer's Avatar
I'm of the newer school of thought that the engine is broke in by the time you drive it. If the rings don't seat after getting on it a time or two (don't beat the **** out of it, but do pull it through the band) Then they are not going to.
Old school is x rpm for so long, another for so long, then drive it easy for 5 billion miles... blah blah.
I start mine, let them idle (adjust the valves if you have to), go through a heat cycle or two while sitting still. Makes sure everything is hooked up, plenty of coolant etc.
-Change the oil
Go drive it like you normally would.
-Change the oil (now put your normal stuff in if you run something expensive)
done
Mine saw boost with something like 10 miles on it, and only waited that long because I had just switched to a standalone, new turbo kit, and a new motor all at once.
Old Apr 10, 2008 | 02:55 PM
Lisa33's Avatar
-Change the oil
done
Agree.
Old Apr 13, 2008 | 04:58 PM
DirtyDaveW's Avatar
Lol... "Then drive it easy for 5 billiion miles.."
That's too funny.
Your method does seem to be the rule nowadays. Thanks for the post.
-Change the oil
done
Old Apr 15, 2008 | 01:40 PM
Tricked-Out-Toy's Avatar
MY last rebuild before boost was redlined on the first trip outa the garage and has asked for more ever since. This whole "break in" crap is for the birds.... do you think the guys that race 24hr races that just had to replace there engine the night before take it easy the first couple laps?! NO they beat the hell out of it! if its going to break its going to break, no amount of babying it going to make it better.....
cmyname1
Feb 19, 2015 08:38 PM
grabbem88
Feb 13, 2015 03:09 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
dmaastr
9
Jul 1, 2002 02:22 PM
