Dyno blues
Old Mar 14, 2004 | 09:52 PM
  #16
Highlander's Avatar
Total advance is irrelevant... Every car is different.. and 30 is not a magic number.. some like more some like less.. Personally i couldn't run more than 26 advance with 10psi boost. and I still made 607 with afr 190 heads and an S-trim and I did have intercooler.. I did had a 224/236 XE cam though.
Old Mar 14, 2004 | 10:13 PM
  #17
engineermike's Avatar
Highlander, I don't understand something. In e-mail, after looking at my TunerCAT file, you told me that I'm not running enough timing at 34 degrees. But you're only running 26???
Mike
Old Mar 14, 2004 | 10:25 PM
  #18
Highlander's Avatar
Nope.. that was not what I said.. "enough" timing doesn't mean WOT
Besides.. i am running 36 (scantool) 1º/psi retard
so it means... 36-10=26º advance
Old Mar 15, 2004 | 06:14 AM
  #19
RealQuick's Avatar
Good thread. Subscribing...
Old Mar 15, 2004 | 06:31 AM
  #20
Well, I'm not sure about you, but I do all my dyno testing an drag racing at WOT. . .
I've dyno'd my car with several different timing settings and found the most power at 35 - 36 degrees total timing when read by the scantool.
Mike
Old Mar 15, 2004 | 06:50 AM
  #21
RealQuick's Avatar
Mike
I think thats what highlander means? He has his set at 36 as well, but with the timing retard based on boost, he loses 10 degrees at 10psi for a total of 26 degrees advance. Maybe you understand this as well, just thought I would state the obvious.
Old Mar 15, 2004 | 06:52 AM
  #22
Highlander's Avatar
WOT timing is not the only timing and it affects overall feel of the car and WOT power.
Old Mar 22, 2004 | 01:44 PM
  #23
95 Silver TA's Avatar
Botch,
Have you tried anything new? Plugs, octance ..etc.
Just curious to see how you made out.
Thanks,
Claude
Old Mar 25, 2004 | 05:12 AM
  #24
Zac2003's Avatar
Originally posted by 95 Silver TA
Botch,
Thanks,
Claude
Old Apr 1, 2004 | 02:28 PM
  #25
Botch's Avatar
I haven't had it back on the dyno yet. I put an msd-6al on it and richened up the fuel mixture some. I haven't had much time to work on it though. I'll keep you guys posted.
Later,
Botch
football4life
Oct 4, 2015 07:48 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 17, 2015 11:53 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
