Dyno blues
Total advance is irrelevant... Every car is different.. and 30 is not a magic number.. some like more some like less.. Personally i couldn't run more than 26 advance with 10psi boost. and I still made 607 with afr 190 heads and an S-trim and I did have intercooler.. I did had a 224/236 XE cam though.
Originally posted by The Highlander
Nope.. that was not what I said.. "enough" timing doesn't mean WOT
Besides.. i am running 36 (scantool) 1º/psi retard
so it means... 36-10=26º advance
I've dyno'd my car with several different timing settings and found the most power at 35 - 36 degrees total timing when read by the scantool.
Mike
Originally posted by engineermike
Well, I'm not sure about you, but I do all my dyno testing an drag racing at WOT. . .
Mike
Mike
I haven't had it back on the dyno yet. I put an msd-6al on it and richened up the fuel mixture some. I haven't had much time to work on it though. I'll keep you guys posted.
Later,
Botch
Later,
Botch
Sep 17, 2015 11:53 AM
Sep 11, 2015 09:44 AM
