Draining turbos when they are lower than the oil pan
Hello guys...
I've been faced with this problem in a TT lt1 corvette we are building..
The turbos are lower than the oil pan, so it cannot be gravity drained back to the oil pan...
My question is:
I though of using a wet sump to drain the oil back from the turbines, but I am unsure how to do this.. Anyone have an idea... or a better way to do it?
My question is:
Your best bet is probably a scavaging pump. I would probably make a container that held a qt of oil. dump the feeds down hill then put the pump on the bottom of the container. Use -10 line to the container then probably a 12 to the pan.
stockssn2o
05-25-2015 08:54 AM
