does intercooling keep away detonation beter than mynthaol/water or are they equal
Originally posted by Birdie2000
Julio,
What parts would I need from you for a progressive system for my supercharged Formula? Also, this may be a stupid question... but do I need/want the 3 bar MAP?
Julio,
If you run an SC, you can use a 2 bar sensor, pump, nozzle, lines, tank, and controller. Its not rocket science..thats the good news. And alcohol when pumping it in, is extremely forgiving. If you shoot too much the motor lays down, but no harm. Its not like a fuel injector where your looking for a perfect number/flow.
Originally posted by engineermike
I have to ask, though, if you are going to inject an oxygenated compound into the intake tract for the purpose of cooling the intake charge and adding power, why not inject nitrous oxide? It will cool much better than alcohol, plus has more oxygen.
Mike
Mike
If your detonating and you shoot some NOS into the cylinder.. your crankshaft goes away. See NOS makes power but it by far has no detonation reduction properties like water/alcohol injection. yes it cooler till it hits the back of the valve, one inside the chamber..kaboom.. hence why added octane is needed with NOS. If not everbody could run a 250 shot on 87 octane.
Now to play with ideas, hydrogen peroxide, acetone are two others..
I'll stick to whats worked for so many, and keep my smiles per gallon high.
Mike
Mike
They both will cool the intake charge, though which cools better I suppose would depend on the amount used ??
Hope this add a bit more light
LWM
I'm curious...
How many miles per gallon do you get with alcohol injection?
Let me clarify what I mean so you don't misunderstand.
Lets say I built a turbocharged engine, ran 20lbs of boost and used alcohol injection to control temperature/detonation.
Lets also say that I had a one gallon resevoir to hold the alcohol being used for injection.
If I wanted to take the car out for a drive one fine Saturday, how long could I expect to drive on that one gallon of alcohol before I would need to refill the resevoir?
Originally posted by LameRandomName
I'm curious...
I'm curious...
You can buy methanol at most paint stores or hardwares. If they don't have it, they should be able to get it. Washer fluid will work as well.
Rich Krause
I had been running water/alcohol mixes and straight alcohol for the last 3 years on my supercharged 98 ls1 TA.
Non intercooled and running from 15-20GPH nozzles.
A 15GPH nozzle with straight alcohol injected at 140psi directly after the blower output, only dropped charge temps to 160-170' on a 50' day while seeing about 14psi boost.
This is a over spun G -trim Vortech.
Needed to be run at around 10.7-11.0 AF for no detonation even with 100 octane CAM 2 pump gas.
I had some left over A.C. parts and fabbed up a water to air intercooler using an A.C. evaporator core and removed the alky injection. Peak IAT at full boost on a 65' day is now 118' day at 13 psi with the fabbed up intercooler. Lost 1 lb of boost with the intercooler and dropped temps about 50 degrees with no alky.
Have not yet run the car and probably won't ever have a direct comparison as I'm installing a new rear-end and different gears right now.
But SOTP tells me it's about the same speed, yet the intercooled combo has proven much less liable to detonate than the non intercooled alky combo.
I had used from 1 to 4 nozzles and injected it at many different locations including through the blower. Yes, water will work fine without alky but you lose a lot of power when you get the flow high enough with straight water to stop all detonation with an aggressive timing table.
Most of the tractor pullers using water injection are diesels.
some pics of old and new combos here. I think in the old combo photos I did not have the alky system hooked up at the time.
http://community.webshots.com/user/s_j_h
Steve
Steve
Originally posted by just me
Yes, water will work fine without alky but you lose alot of power when you get the flow high enough with straight water to stop all detonation with an aggressive timing table.
although my logic would imply no. Did you alter the amount of fuel used, when water was used in conjunction? Could/would the power lose you experienced, have been reclaimed, with an attending adjustment of fuel flow? Personally, would not attempt, under for power, without monitoring detonation and EGTs.
I think in the last 3 years I have read every old and new SAE and naca paper on the subject of auxiliary fuels and combustion coolants on the net.
Just as an experiment as I knew I was pulling the motor soon,
I ran enough water through this thing once it would not rev beyond 4500rpm and the valve covers were full of condensate after a few seconds.
It was way more than the total fuel volume used.
I have an in car wideband and good pcm monitoring software.
I use ls1edit to tune the pcm. Yes, I pulled back the fueling. Never leaner than 12.5-1 though.
Also the thing about charge cooling. Tell you what, guys who see a huge drop in temps, make darn sure your sensor is not to close to the nozzles or you'll just end up wetting the sensor and measuring the temp of the fluid! I used to think I had great charge temp reduction until I moved the nozzles way back from the temp sensor.
The thing is as (Chris B already pointed out), water is able to get you more power than without with marginal pump gas.
However, water is not comparable to the same tune-up using a pure fuel that has sufficient octane to stop detonation.
In other words, run 20psi at a 12:1 AF with 114 octane and 25' timing.
run the same 20psi and 12:1 AF with 93 pump gas and 50% by volume of water and 25' timing.
The water injected engine will be down on power because of the thermal losses.
Don't get me wrong. Used both water an alky for last 3 years. It DOES work. But it's not a miracle either.
Going back to the original question of this thread, right now I think intercooling may be a better approach if it's choose one or the other. Of course you could do both.
Steve
Steve
RUENUF
Mar 13, 2016 03:37 PM
