difference between p-1sc/d-1sc
Old Mar 16, 2006 | 10:08 AM
michael_grayson's Avatar
Say guys whats the difference between the 2 of these. My car has the p-1sc, is that not as good of charger as the d-1sc or d-1. I hear people say they wish they had a d-1. Also how much boost is mine good for. Thanks!
Old Mar 16, 2006 | 10:17 AM
KS91Z28's Avatar
Re: difference between p-1sc/d-1sc
A P1SC has a straight cut blade impeller, whereas a D1SC has a more aggressive curved blade impeller.
Old Mar 16, 2006 | 11:21 AM
MonkeyBoneSS's Avatar
Are you running on the stock block and heads still with the P1SC?
Old Mar 17, 2006 | 10:09 AM
Yes I am, but I have a 388 with lt4 afr heads and intake waiting to be put in but I was going to wait untill this one dies. Im still working on making the supercharger work right so I figure I would get real familiar with how everything works before I throw my big gun under the hood!
Old Mar 18, 2006 | 12:43 PM
CALL911's Avatar
The 2 biggest differences between the P-1, and the D-1, is the performance, and as a consequence, the price. The P-1SC is a great baseline unit that in most cases can be put on with very little to no need to change any of your fuel setup (ex. injectors, fuel pump, ect.), and you can still expect substancial gains in power. However the D-1SC is going to require motor work(pistons, ect), and a changed up fuel system with a good tune in order for your motor to last and perform properly. A friend of mine put his theory to the test when he put a D-1SC(twin intercooled), on his stock LS1, and even with small boost for the D-1, along with the larger injectors, and fuel pump, his motor lasted about 5,000 miles before his motor was toast. I have seen the P-1 put out more than 475 at the wheels on good applications on F-body's before, I have also seen the D-1 put down well over 850 at the wheels. The D-1SC kit will run around $4500 depending on who you talk to. The P-1SC costs quite a bit less (maybe $3000 or so, not sure since I didn't directly price one out).
I just bought a D-1SC a week ago, and I am looking to only use a mild amount of boost in it (12#) and I should have somewhere around 650 at the wheels with my set up. The D-1SC is capable of more than 18#'s, where the P-1SC I believe does under 10#'s. (mostly I have seen 6-8#'s used).
I hope this answers your question.
Old Mar 19, 2006 | 09:59 AM
Thanks for the input CALL911, Say I see that there are 2 options for the p-1sc, theres a 8psi version and a 10-14 psi version. Are they the same charger just have different pulley sets. One more thing, can a guy send in the p-1sc to ATI and have it upgraded at all. Thanks again for all your input guys!
Old Mar 19, 2006 | 03:13 PM
CALL911's Avatar
Don't quote me on it, but I believe you will have to buy the D-1SC, you can't "upgrade" from the P-1SC. Also, the only difference between the #'s of boost for the P-1 should just be the pully size. Again, I am more familiar with the D-1, than the P-1, so I could easily be mistaken here.
Old Mar 20, 2006 | 09:02 AM
JAILBAIT's Avatar
The P-1SC can be upgraded to a D-1SC
Old Mar 20, 2006 | 12:45 PM
markinkc69z's Avatar
Upgrading to a D1SC from a P1SC at the time of a new system purchase: $415
Upgrading the P1SC to a D1SC at a later date: about $1280
The D1SC can usually, not always, be pullied down to match the airflow of the P1SC for a particular system.
Old Mar 20, 2006 | 03:20 PM
xxsaint69x's Avatar
here is a pic of my D1 next to Fikse FM5
how come there is so much difference between p1 d1 and F1 if they all use the same housing?
Old Mar 21, 2006 | 11:42 AM
CALL911's Avatar
After doing some research, and then coming back to the thread, yes, the P-1 is definatly upgradable to the D-1. Again, I didn't know a ton on the P-1 system.
Old Mar 21, 2006 | 11:54 AM
Ponyhntr's Avatar
Different impeller sizes and profiles.
Old Mar 21, 2006 | 01:02 PM
How much boost should my p-1sc be good for before I need to upgrade!
Old Mar 21, 2006 | 01:11 PM
Ponyhntr's Avatar
On a close-to-stock LT1, a P1SC should be good for about 12 psi.
Old Mar 21, 2006 | 01:13 PM
Will it make more on a modified motor with a blower cam.
