D1SC owners, what piping did you use from the blower to the elbow??
Old Jan 30, 2007 | 09:32 PM
  #16
CALL911's Avatar
Originally Posted by Ponyhntr
It's hard to tell from your pic (it's really distorted on my screen), but it looks like yours is 3". Mine is 3.5", but I doubt you're going to see much of a gain in power by going up. You would definitely NOT gain any boost, but MAYBE lower intake temps. What are your temps now (back when you had the car tuned)?
Temps I'm not really concerned with. (don't know the exact ones from the dyno either). The methanol injection should cool it down plenty this year.
Thanks for the info!
Old Feb 24, 2007 | 03:05 PM
  #17
blown383's Avatar
Ben-
You are limited with your tubing choices because of the ABS module being in the way. Are you wanting to just replace the elbow, or everything that is up top in the engine bay? The elbow you have is the ATI piece, but it's nearly identical to the Trick Flow piece I have. Here's a pic of mine, but notice I don't have the ABS. My setup won't fit on your car.
Ponyhntr - What did you do about IAT grommet on the Trick flow elbow? I would assume under heavy boost the the IAT would get blown out since its only a push in rubber grommet?
-B
Old Feb 24, 2007 | 04:11 PM
  #18
Ponyhntr's Avatar
-B
I still use the push-in grommet, but I'm only running 5-6 psi. ATI's version of this has a screw-in plastic fitting that houses the IAT element.
Old Feb 24, 2007 | 04:40 PM
  #19
blown383's Avatar
I have the ATI piece however its the older intake elbow thats a bit longer. I was debating on whether to cut the pipe short, weld over the "procharger" logo and sand it smooth to be chromed or just get a new elbow out right and have it chromed.
-B
Old Feb 24, 2007 | 04:41 PM
  #20
Lisa33's Avatar
http://www.nonameracing.se/photos/de...Z28/z28082.jpg
Old Feb 24, 2007 | 10:20 PM
  #21
Ponyhntr's Avatar
-B
Yeah, that one is only 3" on the inlet side. ATI's new one is 3.5".
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
