Is a D1SC capable of making 700 rwhp.
Old Mar 14, 2005 | 06:08 PM
96vortechSS's Avatar
On an fbody with proper heads and cam. The differance in price for the D1sc vs. the F1 is $400 dollars and there is only a 125cfm differance between the two. Is there a big differance between the two?
Old Mar 14, 2005 | 06:13 PM
rwb's Avatar
rwb
Re: Is a D1SC capable of making 700 rwhp.
The P1sc will make 700hp, the D1 will surely make it. The only thing you have to worry about is belt slip, unless you haven't built your motor for it.
Old Mar 14, 2005 | 06:56 PM
n2oblkz
Guest
Posts: n/a
This was one issue I was dealing with. I am going to go with the F1 instead of the D1 for no more than it costs. I would rather pay a little extra and have a better blower in the F1. I am wanting to run about 18 pounds of boost and I don't really think that the D1SC would be best suited for that. If I was wanting to only do about 12-15 pounds, I would probably go with the D1. But, I tend to go a little overkill on a lot of things.
Old Mar 14, 2005 | 08:31 PM
Lonnie Pavtis's Avatar
The D-1 actually has a higher boost capability than the D-1SC due to the internal step up ratio. They do flow the same, but the step up ratio allows a larger blower pulley on the D-1 over the D-1SC to help prevent belt slip. Slippage is usually the limiting boost factor (not blower size) unless cogged. The F-1 takes it a step further & will allow a higher overall boost and/or peak power limit.
For reference, the D-1 will make 18+# on a 383 if built correctly & push 700rwhp.
Old Mar 15, 2005 | 08:50 PM
Pro Stock John's Avatar
ATI makes the F1C now right? Is that better than an old F1?
I've seen 4th gen do 700rwhp with D1, I'm sure there are others.
Go YSi!
Old Mar 15, 2005 | 09:58 PM
biggtime's Avatar
I have a D-1 and make that with 16lbs of boost with 600 engine rpm to go before the blower maxes out.
But if you are buying new, buy the F series you can grow into it.
Old Mar 15, 2005 | 11:33 PM
ProchargedLT1's Avatar
What pulley size and what rpm are you turning?
L8er
Old Mar 15, 2005 | 11:49 PM
biggtime's Avatar
I made cog pulleys for mine. I have a 81 tooth lower and a 40 tooth blower. Max D-1 blower RPM is 65,000. With my pulley combo that is 7200 engine RPM.
Old Mar 17, 2005 | 03:34 PM
Ponyhntr's Avatar
Go YSi!
Yes, ATI makes an F1C. It is bigger than an F1, but smaller than an F1R. The impeller in the F1C is smaller, but more aggressive than the F1R. The F1C also has a 5.73:1 step-up, where the F1 and F1R have a 5.0:1.
Old Mar 17, 2005 | 04:35 PM
n2oblkz
Guest
Posts: n/a
^^^^^^^But will the F1C fit in a 4th Gen F-Body without major modification like the F1?
Old Mar 17, 2005 | 05:51 PM
Ponyhntr's Avatar
No, the case is the same, just the internals change.
Old Mar 17, 2005 | 10:02 PM
n2oblkz
Guest
Posts: n/a
Posted by: Ponyhntr
Ok, I am a litte confused, I was planing on using a D1SC but when I found out that the F1 will fit without problems because it is the same size case as the D1 and uses the same bracket, I figured I would just step up and get the F1. Now, is the F1C the same case size as the F1 and like you say, will fit the same as the F1 and the D1SC using the same bracket?
Old Mar 18, 2005 | 10:31 AM
Ponyhntr's Avatar
Sorry for the confusion, I mis-read your post. The F1C has the EXACT same outside dimensions as the F1. The F1R is the same as the F1, but the compressor housing is .75" larger in diameter. The F1C pretty much has the same compressor wheel as the F1R, but it's smaller to fit in the F1 compressor housing.
All of the F1x (and F2) blowers will bolt to the same brackets as the P1SC and D1SC.
Old Mar 18, 2005 | 07:15 PM
n2oblkz
Guest
Posts: n/a
Hey, thanks, I will have to check into the F1C whenever I am ready to buy!
Old Mar 20, 2005 | 08:57 PM
tubby's Avatar
gowith the F series you'll be much happier
