Is a custom Cam worth it for me on boost?
Old Feb 27, 2008 | 01:37 PM
Tricked-Out-Toy's Avatar
Im looking ahead and trying to piece together my internals for my DIY T70front mount log setup. Im reusing my LE3 heads, Morels, ported intake, 58mm tb, and purchasing a forged crank, eagle H-beams and JE pistons (-22cc). Ill be selling my LE2 cam since its on a 107LSA and was thinking about picking up this one
https://www.camaroz28.com/forums/sho...highlight=bret
The question is, Is it worth it over an off the shelf grind? My goals for the T70 are 600rwhp but ive built it so I can upgrade to a T76 down the road, with Logs I think im limited to around 700 even with the T76.
Old Feb 27, 2008 | 01:53 PM
jsetzer's Avatar
I'm trying to find a reverse split cam. With logs your hot side is going to be pretty inefficient,, so lots of back pressure.
I have read that more intake duration and less exhaust can help in these cases.
I am running a 218/224 cam and I know I have other issues to work out too but I don't like it. Want something like a 234/228 on a 114-115 I think for me.
Either way I just don't like that one listed for sale, not for turbo.
Old Feb 27, 2008 | 02:07 PM
The .24X and the .6XX is what scares me. I dont want anything bigger than my LE2. Id also like to keep the lift below .600 W/ my 1.6 promags.
Old Feb 27, 2008 | 10:07 PM
slomarao's Avatar
i would get a custom cam for any application. I think theres a decent gain from a shelf cam, I would take to cam motion for a turbo cam. Maybe comp, if you look on forcedinductions.com or talk to jose you should be on the right path.
Picking a boost cam is not a easy thing.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
super83Z
Jul 11, 2002 10:16 PM
