Is a compression Ratio of 7.8 to low.
Old Jun 18, 2003 | 04:09 PM
Formula Fbody's Avatar
Hey guys I have the chance to get some airflow research heads (72cc chambers) the only problem is that my compression will be around 7.8 to 1. Is this to low? I have a 383 and a D1 intercooled on a 94 trans am lt1. whats your guys opinions on this type of setup?
Thanks for the info,
Kenneth
Old Jun 18, 2003 | 04:28 PM
dsmfan95's Avatar
7.8:1 will give you lots of room to turn up the boost or have more error in tuning.
What's a D1, sorry but I'm a newbie to the F-body technical terms.
Old Jun 18, 2003 | 05:01 PM
Tech's Avatar
D1 is a procharger similar to T trim.
Old Jun 18, 2003 | 05:03 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
why not just mill the heads down to get the compression up a bit? I would say that is way too low. With NA lt1s running 12.5:1, you can gauge how low 7.8:1 would be!
Old Jun 19, 2003 | 12:51 AM
RobK's Avatar
Last I read, Top Fuel is 6.0 CR!
Old Jun 19, 2003 | 08:42 AM
Yeah I know that they run 6.0 : 1. and if im running 7.8 to 1 that will give me room for a lot of boost. I was mostly worried about idel and things of that nature. I know the compression for boost will work fine at that compression level.
Thanks for all the info guys, I will post my results after the head install.
Thanks,
Kenneth
Old Jun 19, 2003 | 09:11 AM
kmook's Avatar
Advanced Tech Moderator
LOL. My last 383 was 8.3:1 c/r for the D1... but i never got the D1 installed so i was driving around on that n/a for a long time, and it wasnt bad at all
So 7.8:1 with boost is totally fine in my opinion.
Old Jun 19, 2003 | 10:28 AM
SantaCruz163's Avatar
The ratio is fine. Run 18# on the D1 and you'll be fine. The intercooler will help you out as well as the low compression.
Old Jun 19, 2003 | 10:57 AM
racr4jc's Avatar
Well you know with volkswagen motors, 8:1 is considered high compression.
Old Jun 19, 2003 | 11:04 AM
Hey kmook could I get your number? I have your old D1 from shane and Have some questions on the injector size and things like that. Maybe you could help out. you can email me your number at: Cmyskill@aol.com or formulafbody@aol.com
Thanks,
Ken
Old Jun 19, 2003 | 11:16 AM
kmook's Avatar
Email Sent Ken.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
