Compression question
Old Dec 21, 2003 | 10:19 PM
sleepy_z28's Avatar
My LT1 is ready to come out for a forged 355 rebuild. I've bought a 6-8 PSI nonintercooled kit. The cam I've got for it is a 224/230 XE. The heads will be mildly ported. My question is, what compression should I set this thing up for? Also what head gaskets should I go with? Emissions are not a concern if, if that matters. A compression change comes by way of piston selection, correct? Or is there something else involved?
Old Dec 21, 2003 | 11:11 PM
1994B4C's Avatar
Congrats on the purchase. You will be fine with compression anywhere between 8:1-9:1. Since you are staying with the shorter stroke of the 350 finding a pistons for that low of compression will not be a problem. With 8lbs of boost you don't need to have it O-ringed and copper gaskets, just a good quality gasket will keep it sealed.
Old Dec 21, 2003 | 11:24 PM
sleepy_z28's Avatar
Thanks 1994B4C. Any sugestions on what brand of pistons to look at or others I should stay away from.
I've been N2O and I'm pretty pumped about changing to the boost.
Old Dec 22, 2003 | 01:59 AM
1994B4C's Avatar
I would get a 2618 forged piston. There are several quality piston companies, Ross, Venolia, Probe, JE, etc...I personally bought Ross for the car I am trying to sell now.
Old Dec 22, 2003 | 11:27 AM
BOOST FED 95Z's Avatar
In my 357 I am running JE's 9:6.1 on around 15 psi pushed by a t-trim. So far so good.
Scott
Old Dec 22, 2003 | 01:00 PM
94SLUG's Avatar
I went for a JE 8:1 as I consistantly move to places that sell terrible fuel (colorado 91). JE is a good name with a good price.
Old Dec 22, 2003 | 03:16 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
what kinda of blower is it? I ASSUME an s-trim (juding by the way you worded it). if you plan to only run "6-8psi" I would keep the compression up around 10:1.
If you are going to run more boost(which you should) say around 12-13psi, run between 9:1 and 9.5:1
Old Dec 22, 2003 | 08:42 PM
rskrause's Avatar
Moderator
You should do fine with the Fel-Pro #1074, which is the gasket most people are using. Held up fine on mine with 17psi of boost plus some nitrous. I am going to try the Cometics this year, but the extra $$$ is clearly not warranted for what you have in mind.
As Jordan said, CR and boost are related as is the cam. Also, you need to take into account the fuel you plan to use. I hope you aren't disappointed. 6-8psi on an LT1 with mildly worked heads may not be as fast as you want. If you are building a stout shortblock, I would say go for lower CR and more boost. What blower is it?
There are other good pistons out there for sure. But I would like to put in a vote for JE. Their "Extreme Duty" blower piston is a nice piece, though a little on the heavy side.
Rich Krause
Old Dec 22, 2003 | 11:56 PM
sleepy_z28's Avatar
Thanks for the info guys. It's a paxton kit that I bought from one of the guys on this board. Yes, I'm aware of the problems that can go along with the GSS style. If it fails I'll swap it for a newer gear driven style. So for a street set-up, can I leave the CR at stock with the cam I intend to use? If that's the case then it makes things a whole lot simpler. I was just concerned with how the cam might affect things in this set-up. I have 93 octane available just around the corner from me, which I run only anyway.
Old Dec 23, 2003 | 05:37 AM
magius231's Avatar
you will make more power with lower CR and more boost than you will with higher CR and less boost. If your not into making a ton of boost, I'd do what Jordan suggests.
Old Dec 27, 2003 | 08:48 PM
ATMINF's Avatar
JUst my 2 cents but sell the Paxton and get a ATI or a Vortech. That paxton won't last long.
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Red_94Formula
Jan 22, 2015 12:17 AM
