Interesting concept on oil return
Old Dec 27, 2003 | 03:34 PM
12Second3rdgen's Avatar
I saw this in a Car Craft I have. They were using the vortech YS trim. Instead of plumbing the oil return line into the oil pan, they ran it back into the valve cover. What do you guys think of this?
Old Dec 27, 2003 | 03:57 PM
96 WS6's Avatar
You would probably need a scavenging pump because the plane the blower is on has to be higher than the plane the valve cover is on. It has to have a gravity drain, as long as it does you are good.
Old Dec 27, 2003 | 05:07 PM
Makes sense, it was vortech's marine blower so it sat way high on the motor.
Old Dec 27, 2003 | 10:56 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Still better to drain to the oil pan.
Less chance of filling up a valvecover, and less HP loss due to windage (more oil draining back over the reciprocating assm.)
F'n1996Z28SS
Aug 23, 2023 11:19 PM
captcorvette
Mar 7, 2015 12:37 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
