Coil relocation with a procharger
Old Apr 2, 2006 | 10:10 PM
xxsaint69x's Avatar
i dont have the bracket, can someone post a pic of one and how it is mounted.
Old Apr 2, 2006 | 10:24 PM
lethal93ta's Avatar
Re: Coil relocation with a procharger
it just gets moved from the head to the back side of the procharger bracket. there should be 2 holes there to mount it to.
Old Apr 3, 2006 | 08:33 PM
Procharged94Lt1's Avatar
I had problems with the holes when I tried to mount my Accel ignition system. I ended up having to make a bracket to mount the coil.
If you have a stock igntion system you should be fine..
Old Apr 4, 2006 | 03:36 PM
xxsaint69x's Avatar
hmm i have a different tensioner on there so the holes are no there...hmmm
Old Apr 4, 2006 | 07:38 PM
hulettsz28's Avatar
if you have the stock coil, then it just goes on the back of the bracket your head unit went on, facing in the opposite direction as it was on the cylinder head. i dont know what you are saying about a tensioner. I had msd super conductors and needed to order a custom wire kit from MSD to make a cable long enough to reach, the one supplied for the ignition coil wasnt long enough so you may have to do this too just to fair warn you. good luck
Devinfoote87
Feb 12, 2016 03:21 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
95blkss
Jul 13, 2015 01:28 PM
