Cogs, T-trim, Longetivity
Old Feb 24, 2004 | 09:47 AM
Highlander's Avatar
I heard from a friend that the cogs are a bit tough on the cranks front bearing as well as the S/C. Now the T-trim is the Heavy duty and its supposed to widstand the abuse...
What do you guys think about cogs and such? I have a single keyd crank hub...
I may be maxing out this t-trim so I find it a bit advantageous to use cogs.
Any experiences will be appreciated...
Also.. what is more or less the price range we are talking about for this setup?
The other thing is... Is ASP the only source for 7" cranks?
Old Feb 27, 2004 | 04:27 PM
J'S Z's Avatar
Highlander I have an interest in cogs myself.I have been talking to Larry at ASSC Racing(847-473-4720)He makes a cog setup he has the cogs but you can probaly get from ATI.His bracing to stop bracket from flexing along with few other parts that I can't remember.He suggested having the crank double keyed.And use ATI super damper.He did one for his firebird w/ F1 putting out 20+ psi.Call him will be glad to talk to you about it
Old Feb 27, 2004 | 06:28 PM
Pro Stock John's Avatar
No way Larry makes cogs, he must be buying them elsewhere I buy gas from there on a regular basis.
Old Feb 27, 2004 | 06:41 PM
J'S Z's Avatar
Not saying he makes cogs.Just saying that he knows how to make cogs work without trashing your crank.
Old Feb 27, 2004 | 08:42 PM
Willie's Avatar
Larry does not fab cogs. They are ATI pieces. What Larry does is fab the cog idlers and support braces for the main blower bracket. He also fabs the inner hub for the ATI Super Damper which is far thicker than the original. His also uses two keyways.
Most important: All the above is for a third gen. His Firebird is a '92 running a 350 TPI at 25.8-psig.
I know all this because I run all his stuff on my F1 equipped third gen.
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
96vortechSS
Sep 15, 2003 10:47 PM
bowtiepwr
Jul 15, 2003 08:04 PM
96 Comp T/A
Advanced Tech
Dec 28, 2002 01:39 PM
