Closed or Open Loop. Pros and cons of each
Old May 27, 2009 | 05:15 PM
RUNMYTA's Avatar
Which do you prefer for higher boosted applications and why. I have talked to a couple different tuners and each has their own style. Which do you think is best for 10+PSI?
Old May 27, 2009 | 06:06 PM
jsetzer's Avatar
Assuming you are running the stock computer, you will always be in open loop while in boost. Well PE mode anyways. In WOT the o2 sensors are more or less ignored.
Only reason I would tell someone to tune open loop is a massive cam that won't idle at 14.7 afr.
With the MS I can run closed loop under any conditions - so if you trust your wideband it will add/remove fuel any time. I actually run closed loop close about 15.5 for idle and cruising.
WOT = wide open throttle
PE = Power enrichment mode
Old May 27, 2009 | 09:13 PM
MikeGyver's Avatar
What he said. Closed lewp is a wonderful thing.
Old May 28, 2009 | 09:34 AM
mzgp5x's Avatar
In these days of the "green" people and high gas expense, having the gm pcm with closed loop mode to control part throttle stoic @ 14.7afr can help with fuel costs. So, I have tuned for WOT PEvs.RPM mode @ 12.8afr, and, 14.7afr for part throttle cruz with use of the MAF sensor. My app... 97ss MM6 383ci - D1 ~14/15psi OBD2. I still run the 1 bar MAP sensor, so, the PCM cal is a custom tune with use of a DynoJet WB.
This was my approach, but, you can also get very close to stoic with a speed_density control system with a bit more tuning work.
HTH B.
cristian1311
Apr 22, 2015 10:20 PM
rpm4lalo
Sep 6, 2002 12:46 AM
bowtiepwr
Aug 5, 2002 08:14 AM
FiNSTa
Jul 20, 2002 10:57 PM
Z284ever
46
Jul 2, 2002 07:13 PM
