Changing pulleys do I need to adj. By pass valve?
Old Apr 1, 2006 | 08:24 PM
BMAN'S SCZ's Avatar
I started with a 8# setup.(procharger P600B Twin IC) Now I am setup to run 12# do I need to adj the spring in the stock ATI by pass valve? Will it bleed off after 8#? I am not sure how this works. Can someone please fill me in on this Thanks....John
Old Apr 1, 2006 | 09:56 PM
JWS6's Avatar
Re: Changing pulleys do I need to adj. By pass valve?
my understanding is that the bypass operates by vacuum and only has a diaphragm. I'm not adjusting mine as I just put 12lb pullies on so I hope I know what I'm talking about! It shouldnt be an issue
Old Apr 2, 2006 | 12:58 PM
1BadAzzGT's Avatar
Talking Re: Changing pulleys do I need to adj. By pass valve?
If so you can always upgrade to the Bosch 114 .. U can get it at your local VW/Audi dealer I run two of these bypasses venting to the atmosphere and they are just fine.
Old Apr 2, 2006 | 03:24 PM
Sean94Z's Avatar
You don't need to adjust it. It only opens under vacuum. It's not a wastegate like a turbo. ATI claims their valves are good up to the F1 series, then you need the race series.
Old Apr 2, 2006 | 07:01 PM
BMAN'S SCZ's Avatar
Thanks guys for clearing that up for me.......John
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
