About to buy this combo what cam would you use
Old Apr 1, 2006 | 09:37 PM
TransAm2k4's Avatar
383 complete running engine LT1
Eagle forged crank
Eagle SIR rods
TRW forged pistons
Sealed Power rings
GM Hot cam
Comp hyd roller lifters
hardened pushrods
Roller rockers
BBK throttle body
9.5:1 comp ratio
New opti
MSD wires
Stock Heads New component
Comes with the Vortech Superchager and Aftercooler set up. Also will come with JBA shorty headers.
I will change Heads for AFR and put ported intake with 58mm tb and LT headers. I also a cc 306 cam. Would you recommend changing to cc 306 or leaving the hot cam in. Or is it really worth just buying another one and if so which one?
Old Apr 2, 2006 | 05:40 PM
TransAm2k4's Avatar
Re: About to buy this combo what cam would you use
So would it be 306 or hotcam or maybe other?
Old Apr 3, 2006 | 07:59 AM
RealQuick's Avatar
Some common blower cams are the 218/230 or the 224/236. Do a search and type in "cam" and search the forced induction section. You'll find a ton of info.
Old Apr 3, 2006 | 08:01 AM
TransAm2k4's Avatar
would it be worth changing over a hot cam or a cc306
oldschool
Feb 9, 2016 09:21 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
