can i regulate down a fuel injected pump to run a carb
Old Sep 14, 2005 | 12:42 PM
Daddyo's Avatar
planning on running a P1SC blowthrough set-up.alreadt have a areomotive A1000 pump can i regulate it down to run the carb. car craft did something in there lastes issue, but no info on the pump they used just the regulator.
thanks.
Old Sep 14, 2005 | 07:12 PM
engineermike's Avatar
Re: can i regulate down a fuel injected pump to run a carb
I've done this before. You have to use a bypass-style regulator on the return line, with the return line tee'd into the feed line. Worked like a charm. The plus is that the pump will handle more hp at the lower pressure.
Old Sep 15, 2005 | 12:34 AM
blown3rdgen's Avatar
That is the exact pump I run with my blow thru set up. Just get the matching regulator (return style/ boost referenced)
Matt
Old Sep 15, 2005 | 08:04 AM
markinkc69z's Avatar
You would probably want to run an Aeromotive 13204 regulator.
Old Sep 15, 2005 | 11:32 AM
Daddyo's Avatar
thanks guys,thats what i'll do.
engineermike:so on the return line you would t' it back into the feed line and not back to the tank it's self like on most return style fuel systems? if so that would make things easier for me.
thanks,
johnny
Old Sep 15, 2005 | 12:33 PM
No, you still have to run it back to the tank. What I'm saying is that the return line should "t" into the main feed line, go through the regulator, then back to the tank.
Old Sep 15, 2005 | 12:56 PM
Daddyo's Avatar
i got it now, thank you.
DirtyDaveW
Dec 1, 2016 05:37 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
