Cam Question
Old Feb 8, 2003 | 02:40 PM
yenkoz28's Avatar
Cam Question
I see you guys like the comp cams extreme energy 218/230 and have a question. My car is a 91 Z28 setup with 12 bolt 3:08 gears, Aftermarket T56, and I'm planning a 350 with AFR 190 heads, 9.0:1 compression, Accel superram base, AS&M largetube runners, holley 52mm throttlebody, 1 3/4" SLP headers, with a single 3.5" exhaust, with my D1SC setup running around 15 psig. Do you think the 218/230 cam would work good with my large tube runner setup? I'm looking for something very streetable that will see little track time. How is the idle quality with this cam and at what rpm? Also would more lsa like 115 or 116 help me more with a long tube runner setup? Thanks for the relpies.
Old Feb 8, 2003 | 04:50 PM
rskrause's Avatar
Moderator
What's the LSA on the cam you have? If it's the usual 114, i wouldn't switch for that reason. In genreal, the cam you have should work fine.
Rich Krause
Old Feb 8, 2003 | 05:06 PM
yenkoz28's Avatar
Right now I am running the stock 305 which has a 114.5 lsa with 8 psig of boost, but I'm looking to build a 350 described in my post above.
Old Feb 8, 2003 | 05:14 PM
rskrause's Avatar
Moderator
I think it's a good cam for the purpose.
Rich Krause
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
