cam motions recommendation for my car hyd roller
Old Sep 22, 2005 | 02:53 PM
will62085's Avatar
im thinking of sticking with a hyd. roller...heres what cam motion recommended...what do you think?
twin turbo lt1, 1 5/8 turbo headers, MP t-70 turbos, 20-22 psi on race gas, 6 speed, 3800 lbs, shooting for mid/low 9's, street/strip car
Grind Number X2341-2341-14+2
Duration (intake/exaust) 234/234
Lift (intake/exaust) .576/.576
Lobe Center Separation 114
Intake Centerline 112
Old Sep 22, 2005 | 04:33 PM
engineermike's Avatar
Re: cam motions recommendation for my car hyd roller
I'm not sure how the MP T-70 turbos compare to equivalent singles. . . but the cam sounds good. If the turbo's limit you to ~1000 rwhp, then the cam might be on the big side.
Old Sep 22, 2005 | 04:51 PM
will62085's Avatar
turbos spool similar to pt-61's, and are capable of 700 HP each
Old Sep 22, 2005 | 06:26 PM
The cam sounds like an excellent choice then.
Old Sep 22, 2005 | 09:08 PM
Rodrigues's Avatar
Try giving somone experience with turbo cams a call, Ken Duttweiler is a friendly guy to start with. A cam is where a lot of the magic happens so take your time
Old Sep 23, 2005 | 12:19 AM
will62085's Avatar
ill call him, but i thought cam motion was big with the turbo stuff? especially over on ls1tech.com
Old Sep 23, 2005 | 05:49 AM
I'm not a big fan of Cam Motion (aka: Slow Motion). They don't own a dyno, Spinmaster, nor are there many turbo motors in the area to play with. I'm also not a big fan of their popular reverse-split turbo cams. However, the single pattern they recommended for you looks pretty good.
Old Sep 23, 2005 | 08:55 AM
will62085's Avatar
btw, how do i get ahold of ken duttweiler?
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
