Cam
Old Aug 6, 2005 | 04:42 PM
akafred's Avatar
Cam
would this cam be decent for a 383 turbo engine
226/224 .568/.548 115lsa
i can get it off a fellow z28.com member
my other option is a hotcam lol
also would this pass a sniffer test??
Old Aug 7, 2005 | 02:18 PM
akafred's Avatar
Re: Cam
no one knows if this would be decent?
Old Aug 7, 2005 | 02:50 PM
rskrause's Avatar
Moderator
Re: Cam
No idea on the sniffer. As far as the cam goes, what is your definition of a "decent" cam? How do you use the car, how much boost, what CR, etc.? In very general terms, that looks like a "decent" cam, but again: I don't really know what you are after.
Rich
Old Aug 8, 2005 | 11:08 AM
akafred's Avatar
Re: Cam
It will be 8.5-9.0 cr 383cid lt1 with 10-15lbs of boost via 2 pcs 60-1 turbos
mostly street driven with the odd 1/4 mile
as far as cams are concerned i am clueless as to what works for what.
looking to make 600+hp minimum
Old Aug 8, 2005 | 11:20 AM
rskrause's Avatar
Moderator
Re: Cam
It seems in the ballpark for a street turbo cam. The heads will be the determining factor in power output. You will need an intercooler to run that much boost (obviously) and/or water/methanol injection.
Rich
Old Aug 8, 2005 | 05:09 PM
akafred's Avatar
Re: Cam
i will most likey use ported stock heads from my sig they flow 260~ cfm i made 416.8 hp na with them. with a hotcam
Old Aug 9, 2005 | 11:26 AM
RealQuick's Avatar
Re: Cam
That cam will work great for what you want. With -5 degrees of overlap, i suspect it shouldnt have a problem passing emissions. Is that a Futural cam? I plan on going with a 226/226 .560"/.560" 114 or 115lsa for my emissions legal 700rwhp setup (still in the works)
Old Aug 9, 2005 | 03:28 PM
mzgp5x's Avatar
Re: Cam
I'm running 231/240@ 0.05" .536/ .558 114 lsa 110In CL. 12 psi pulley on a D1 with a large spearco. I had to play with the timing alot. Now getting it to run decent. Going with a Dyno-Tech wideband. I think my exhaust is somewhat restrictive (3 1/2 mufflex with spintech). 383 with forged internals 9.5:1 afr 190 heads. Learned alot from acceleronics.
Old Sep 12, 2005 | 04:03 PM
akafred's Avatar
Re: Cam
230/236 536/555 lift 114lsa how about this one
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
