bypass options...
Old Jul 21, 2009 | 11:54 PM
97SS0594's Avatar
bypass options...
what are my options beside the ati race one. what about running 2 bosch bypass valves? ive also seen the turboXS type RFL is changeable to bypass, im just trying to find a cheaper option as i blew a ton on the F1A and im trying to conserve a bit of money.
Old Jul 22, 2009 | 10:23 PM
mzgp5x's Avatar
I run two (2) Bosch style type bypass valves. Fabricated a bypass tube for mounting. They work good. I think I purchased them from evolution motor sports in Az. I have tried an HKS SSQV valve. The SSQV holds the boost longer and will not bleed as quickly. But, more cost. So, I will modify the valves a bit. There is no spring adjustment on the vac side of the valve. I will machine spring shims to do this after running some calculations. App... 97ss 383ci D1 7.6-->3.4"pd pulley. HTH B.
Old Jul 23, 2009 | 03:40 PM
97WS6Pilot's Avatar
I'm using a Mondo valve I bought from summit. Its a very high quality piece. I connected a small silencer made out of pvc and fiberglass to the overflow air to quiet down the F1A. With an ATI race bypass this is not an option.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
