building only 4psi of 18... f1a... just rebuilt.
Old 07-21-2011, 03:13 AM
97SS0594's Avatar
After my rebuild on the f1a I'm only making 4 psi. Took the air filter off same result. No belt slip and I did a boost leak check and there is 0 leaks. I checked over the bypass ( big red open race) and everything looks good. I called procharger and they don't have a clue, and bob from brute speed I've exhausted everything he suggested.. I'm at a total loss...what else is there to check? Id rely like to get it 100% so I can put some numbers down with this 383!!
97SS0594 is offline
Old 07-22-2011, 10:28 AM
KS91Z28's Avatar
Re: building only 4psi of 18... f1a... just rebuilt.
Are the impeller blades angled the correct direction? Post a picture of the inlet of the blower.
KS91Z28 is offline
Old 07-22-2011, 06:15 PM
Kevin Blown 95 TA's Avatar
Make sure you didn't have a rag stuffed into the inlet when you put your blower tubing back together I did this once with a giant wad of paper towels and by the time I figured it out, half of it was all shredded and went through the engine On my car though, I didn't so much lose boost, but it was making my throttle body act funny since it wouldn't close all the way... Not the smartest thing I ever did, but I blame it on the beers I drank while polishing up the parts one boring afternoon.
Kevin Blown 95 TA is offline
Old 07-23-2011, 12:47 AM
97SS0594's Avatar
We thought we missed some paper In the intercooler but there's a ton of air passing through it still... my impelled looks different after the rebuild. I sent the pics to procharger and hopefully I can get it figured out!!
97SS0594 is offline
Old 07-24-2011, 02:56 AM
97WS6SCharged's Avatar
What have you done to test the charge pipe/intercooler and bypass?
97WS6SCharged is offline
Old 07-24-2011, 02:14 PM
97SS0594's Avatar
i built a boost leak tester (ive built a few for DSMs) and did find a couple small leaks which i fixed. the bypass valve i inspected the diaphragm and it has no cracks holes or tares. only thing i could do is try another bypass...
97SS0594 is offline
Old 07-24-2011, 04:11 PM
onefastmx5's Avatar
what intercooler do you have on there (or do you have one)? I had a problem similar to this, and I made installed vacuum port into my silicon coupler before the IC and hooked the boost gauge to that and I had a 8psi going in, and 1 psi coming out... was just a bad IC i guess, switched to the 4" core and no problems since.
onefastmx5 is offline
Old 07-25-2011, 02:09 AM
97SS0594's Avatar
its an ebay CX racing 24x12x4 core... everything worked fine before the blower went kaput... is there a easy way to check the intercooler? maybe a chunk of the old impeller is crammed in there?
97SS0594 is offline
Old 07-25-2011, 04:32 PM
97SS0594's Avatar
rule 1 check both ends of the intercooler after a catastrophic failure... i had melted nylon covering my foils... blew the cooler out realy good and bam.. lots of boost!!
97SS0594 is offline
Novo
06-14-2016 02:58 AM
Mikes 1994 z28
10-10-2015 07:55 AM
CARiD
09-30-2015 05:44 AM
pepon214tx
09-20-2015 04:48 PM
sleeperZ96BT
09-10-2015 08:01 AM
Quick Reply: building only 4psi of 18... f1a... just rebuilt.
