Breathers or catch cans
Old May 9, 2005 | 11:24 AM
Schurters LT1's Avatar
One thing i have been think is to put a breather in both V covers and be done with it....i am going to hide both of them...
Or should i go with a catch can...or somthing.....
What do you guys think here?????
Old May 10, 2005 | 10:10 PM
OBE1 95Z28's Avatar
Re: Breathers or catch cans
If you're running the PVC system, this will let unmetered air into your intake and cause you to run lean. Are you trying to manage blowby?
Old May 10, 2005 | 10:14 PM
RobbyRob's Avatar
Cap off the line to the t/b from v/c and that will end any worries about the pvc system.
Old May 10, 2005 | 10:29 PM
This is what i am going to due....and i think put to breather in the valve covers
Yes i have read about the lean with breathers BUT wont the pcm adjust for this..this is a small amount of air and it is only at idle
No.this will be on a fresh eng BUT i am going to max out the rpm on the T-Trim ...this will end up being allot of pressure in the crank case...i think it is a trade off ....
any more input
Old May 11, 2005 | 01:35 AM
breakmyfootoff's Avatar
I was thinking about using the electric smog pump to pull a vacuum on the crankcase, will this work?
Old May 11, 2005 | 05:45 AM
tici's Avatar
With the breather my low LTFT's went from -2 to +10: I went with a catchcan and a checkvalve 'cause I didn't like it
Old May 12, 2005 | 10:04 AM
OBE1 95Z28's Avatar
I don't believe that the electric smog pump is rated to run full time; it only runs for 2 minutes at start up.
blac94Z
Feb 10, 2015 11:02 AM
HectorM52
Jan 30, 2015 11:34 PM
turbo_Z
Aug 19, 2002 10:50 PM
ericz28w
Aug 19, 2002 07:27 PM
