355/~500hp=how much?
i want a blower on the car, but im hesitent to put it on the stock short block. how much would a 355 cost to handle around 500 to the wheels, the car will most likely never see the track, and will be for shows and cruisin around town once in a while.
Re: 355/~500hp=how much?
thats where im at..er hoping for those power numbers...depends who does your work..some parts can be had fairly cheap...on ebay.. i got some stuff on there.....pistons wont be cheap...i should of put all my mods in a signature etc..but.....do a little leg work...round numbers.. pistons 700 connecting rods 300 new injectors 400 a supercharger kit..4000 pushrods rollerrockers retainers 500 new crank? head work? tuning? its not cheap at least in my case its like a pandoras box..once ya mod 1 thing, you need to do everythin else... i got a new radiator 600 bucks..3 core intercooler..700 bla bla...personally. put a blower on ..blow up the motor then go from there.... i had a freakish occurence with which lead to. a teardown..but it happens....look at other peoples signatures..see what mods they have..then price out...
im actually waiting for golen to give me a call back. what i want is a solid short block, that i can put the stock heads/cam or a mild blower cam with the stock heads, and put a blower on and make 450 plus at the ground and not have to worry about the bottom end, and still having room to grow for better heads/cam/intake down the road if it comes to that point.
golen said $2700 for the short block, thats with cast crank, forged rods, and JE blower pistons. then on top of that i would put the stock heads, with a mild blower cam, and then the blower, said it should get me 450 easy.
thats really good..better pistons than i got.....i got a cast crank as well have basically stock heads..3 angle valve job thats all.. a cam per rskrause's specs in process of getting a rear end put in my car..then hopefully get to drive the car some work the bugs out..
Originally Posted by RealQuick
Do a search on Golen on this site...heard some good and bad stories.
BlackLT1_TX
Aug 22, 2004 07:26 PM
Z28x
14
Oct 1, 2003 10:03 AM
