Breathers or catch cans
One thing i have been think is to put a breather in both V covers and be done with it....i am going to hide both of them...
Or should i go with a catch can...or somthing.....
What do you guys think here?????
Re: Breathers or catch cans
Cap off the line to the t/b from v/c and that will end any worries about the pvc system.
This is what i am going to due....and i think put to breather in the valve covers
If you're running the PVC system, this will let unmetered air into your intake and cause you to run lean.
Yes i have read about the lean with breathers BUT wont the pcm adjust for this..this is a small amount of air and it is only at idle
Are you trying to manage blowby?
No.this will be on a fresh eng BUT i am going to max out the rpm on the T-Trim ...this will end up being allot of pressure in the crank case...i think it is a trade off ....
any more input
any more input
turbo_Z
Aug 19, 2002 10:50 PM
