boost control on super charger
Re: boost control on super charger
ive always ben a turbo guys so does a super charger always push 12 ps1(if thats wat ur running) even when not needed or does it kit in or wat.sounds dumb but i need 2 no lol
What happened to your spelling? A centrifugal's airflow delivery is tied to the rpm the compressor is running. When the engine is not under heavy load a bypass valve is open that vents the supercharger's airflow delivery. When manifold vacuum drops the bypass valve closes and then the engine is breathing through the supercharger. As rpm increases the supercharger delivers more air than the engine can normally inhale creating "boost" and pressurizing the intake system above atmospheric.
Originally Posted by jmh96z28
ive always ben a turbo guys so does a super charger always push 12 ps1(if thats wat ur running) even when not needed or does it kit in or wat.sounds dumb but i need 2 no lolwell well.thank you doctor sc.lol.really tho
SpeedJunkee
Jun 6, 2015 04:27 PM
