bolts on the crank pulley keep coming loose
Old Nov 8, 2004 | 10:40 PM
badblackta's Avatar
well I everytime I tighten the crap out of the bolts for the procharger crank pulley it keeps vibrating loose. already lunched one belt. I have the spacer on and everything. any ideas? also does anyone else besides procharger carry crank pullys like 8 rib 12 rib etc.
Old Nov 8, 2004 | 11:39 PM
kurider's Avatar
Re: bolts on the crank pulley keep coming loose
Are you using a new crank bolt? Use some loctite and torque the bolt to 250 ft/lbs
Old Nov 9, 2004 | 04:29 AM
rskrause's Avatar
Moderator
They should be German tight (guttentight) and you should should use Loctite. Is the face of the pulley warped or something?
Rich
Old Nov 9, 2004 | 09:33 PM
badblackta's Avatar
well the last time it came loose it hit the motor for one of the fans and damaged the ribs. I thought that i had the pretty tight because i could see the other end of the bolt coming through the factory crank pulley but i didnt tighten it anymore because it would have come a little too close to the opti
Old Nov 9, 2004 | 10:43 PM
live2race's Avatar
did you grind the stock arrow off the stock balancer
mine did the same thing
watch out because it will ruine the balancer hub
good luck
HectorM52
Jun 23, 2016 08:42 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
MJ_Z28
Aug 7, 2002 07:15 PM
