Blower Cam ideas on 383 build -14psi boost
Old Aug 17, 2013 | 08:27 PM
97superchgedz28's Avatar
I'm doing a 383 build on my 97z28 that has a procharger psc1.. planning on running pulley for 14psi boost. My heads I plan on getting them ported most likely, if not looking into assembled aftermarket heads.
What blower cam minimum and maximum specs based on my set up do you think I should be looking into?
Old Aug 18, 2013 | 12:03 PM
Re: Blower Cam ideas on 383 build -14psi boost
I should mention it is Street and Strip car. Once I figure out which cam, I'm going to figure out my Head set up
Old Aug 19, 2013 | 06:03 PM
97WS6SCharged's Avatar
You're doing it backwards. Figure out the heads and have the cam ground to suit.
Old Aug 21, 2013 | 03:46 PM
ill talk to the machine shop about my port job on my heads then ill get back to the cam..thx!
Old Aug 22, 2013 | 02:46 AM
Before you commit to a head porter ask to see samples of their work and talk to people who have used them before. Some local guys have been working heads for years and can do magic and some just go crazy with a metal bit and call the end result a port.
Old Aug 28, 2013 | 10:31 PM
CALL911's Avatar
Chris is correct in his logic. You could have hand ported stock heads, and a big cam won't be as benefitial as a more mild cam. Then again, if you are getting a large set of aftermarket heads and having them ported, then you have more options and probably could do a massive cam like I have in my D1SC car.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
